Vendor Eibach anti roll kit front and rear sway bars now taking pre orders
Will be available first week of AUGUST. I have 3 on order but i can add more
[B]
Specs:
FRONT OE SWAYS are 26.5mm / 416 pounds per square inch
Eibach FRONT Sways are 32mm
1st setting is 730 pounds per square inch
2nd setting is 900 pounds per square inch
REAR OE SWAYS are 24.3mm / 374 pounds per square inch
EIBACH REAR SWAYS are 29mm
1st setting is 627 pounds per square inch
2nd setting is 741 pounds per sqaure inch
3rnd setting is 860 pounds per square inch
MSRP IS $529
More adjustable options than any sway bars out in the market for the INFINITI G37.
Anti-Roll-Kit | Performance Sway bars Step-3: Essential Part Of The Pro-System-Plus & Sport-Sytem-Plus * Performance Tuned Sway Bars * Improved Handling and Further Reduce Body Roll * Precision Engineered for Pro-Kit & Sportline * Part of the Eibach Pro-System-Plus & Sport-System-Plus * Million Mile Warranty Complete your suspension upgrade with an Eibach Anti-Roll-Kit. While our Pro-Kit and Sportline spring sets are regarded as the primary suspension enhancement components, the Eibach Anti-Roll-Kit allows critical fine-tuning of your car's handling characteristics. Our Anti-Roll-Kit reduce body roll through increased design stiffness over stock bars. The result: increased handling and cornering grip in any performance-driving situation. Manufactured from cold-formed, high-strength aircraft-grade steel for precision performance, and finished with a long-lasting red powder coat finish, the Anti-Roll-Kit comes complete with all necessary mounting hardware and instructions for easy installation.
Not the actual picture but will update once we get the actual products
PM me or CALL US for forum pricing
Thank you
Lou
amplified motorsport
323 881 0882
[B]
Specs:
MSRP IS $529
Thank you
Lou
323 881 0882
