Vendor G37/370Z Akebono Setup Hawk and Ferodo Brake pads
Hey all:
For those who are not familiar with Ferodo, one of the best brake pads for street and track !
Click Here For DS2500 Compound Specification and Detail
Infiniti G37 / Nissan 370Z Akebono Setup
Ferodo DS2500 (Street/Track)
Front Pads - $195.00
Rear Pads - $155.00
Ferodo DS3000 (Street/Track)
Front Pads - $275.00
Rear Pads - $233.00
Hawks HPS (Street)
Front Pads - $105.00
Rear Pads - $79.00
Hawks HP+ (Autocross / Track)
Front Pads - $144.00
Rear Pads - $99.00
Thank you.
Rear Pads - $155.00
Rear Pads - $233.00
Hawks HPS (Street)
Rear Pads - $79.00
Rear Pads - $99.00
Thank you.
Some info with Ferodo Pads !
FERODO Brake Pads Available Here !!
DS2500 - (Street /Club Sport /Autocross)
DS3000 - (Semi Metalic / Track)
DS1.11 (Semi Metallic / Endurance Race)
(Ferodo compound code H)
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, we would recommend the Ferodo DS3000 or DS1.11.
(Ferodo compound code R)
DS3000 is one of the most decorated race pads in the global motorsports market, having won in diverse venues from rally to open wheel cars. The DS3000 has high bite and good fade resistance. It has a slightly rising torque curve, which means that as temperatures go up, bite increases slightly. Although the bite of the DS3000 is slightly higher than the DS1.11, wear rates are also higher. If you are doing extended lapping (30 minute+ sessions) or endurance racing, and are concerned about pad wear rates, the DS1.11 is probably the better choice for you.
(Ferodo compound code W)
The DS1.11 is one of Ferodo's latest race pad offerings. It has slightly less bite at high temps. vs the DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. If you want a pad that you can thrash all day without having it burn up or fade, the DS1.11 is a great choice.
