SPC Front and Rear Camber Kit Combo Package | Exclusive through THMotorsports
So since our last thread was so epic, I decided to create a new thread that would make purchasing even EASIER
We were the first ones to bring you these camber kits, and we still have the best prices around
72130
INIFINITI G35 ADJ. UPPER ARM
These front upper control arms will give you -1 degree to +1.0 degree caster change and up to -2.5 degrees to +2.5 degrees camber change. Simply replace the OE front upper control arms and dial in your suspension angles with our patented sliding ball joint and caster plate. Whether you want to tune your suspension for the ultimate in handling performance, minimize tire wear or easily move back and forth between the two settings, these are the arms to get the job done.
Front Adjustment range: Camber: -2.5 degrees to +2.5 degrees
Caster: -1.0 degrees to +1.0 degrees
Installation time: .6 hr/side
Required: 1 kit per axle
Applications:
Infiniti
2007 & Up G35/G35x Sedan
2009 & Up G37 Sedan
2008 & Up EX35 FWD/AWD
2008 & Up G37 Coupe
Nissan
2009 & Up 370Z
72260
G35/37 REAR CAMBER ARM
The 72260 Adjustable Rear Arm for the 2007 G35 offer maximum adjustment for camber and toe. This is the perfect kit to adjust rear angle for optimum handling and to maximize tire life, adjusts camber+/-4.0 degrees and toe +/- 3.0 degrees. Use the 85125 rotary files to elongate the OE toe slots.
Rear Adjustment range: Camber ±4.00 degree Toe ±3.00 degree
Required: 1 kit per wheel
Applications
72050
Nissan: 2002 & Up 350Z
Infiniti: 2003 - 07 G35 Coupe, 2003 - 06 G35 Sedan
72260
Infiniti: 2007 & Up G35 Sedan
How to order???
Click this link: SPC Front and Rear Combo Kit
Press: Add to cart
Proceed to checkout and add billing info
Wham, Bam, $509 for a full kit shipped in the lower 48
: Send a PM : lpawlik@thmotorsports.com : lpawlik@thmotorsports.com : 1.800.959.0145 ext. 104
: Like Us on Facebook
