Dead Spot In Steering
I feel like I'm going crazy because of this dead spot in my steering. When I turn the wheel there will be some movement before the wheels actually turn. It mostly happens when turning left, but will do it to the right as well but not as often. I also noticed today when going straight and possibly over some bump in the road the wheel turned backed to center without moving the wheels.
I recently had a clutch job done but I wouldn't think that would cause this to start happening, but between that and being sick I didn't drive for almost 2 weeks. I thought initially I was getting motion sick from driving while sick but there definitely has to be something wrong with the steering.
I noticed the power steering fluid was low, so I topped it up for now before I get to flush it this weekend. Even topped the steering feels sloppy. Hopefully someone can point me in the right direction since I can't find any other threads even just searching "power steering".
Try this:
• While standing outside the car reach in and turn the steering wheel 4-5" in each direction WHILE looking at the front tires.
You should see a direct correlation, between what you see and the motion of the wheel.
If there is some free play or if you hear a "metal tick" or "tap" type sound the steering rack might be bad, or that universal joint might be loose.
If you want to have a look at the steering shaft universal joint, jack up the front of the car and remove the front left wheel.
Follow the tie rod to the rack and pinion.
If you look through the opening at the back part of the wheel well, you will be able to see where the steering shaft joins to the steering rack.
Since there might be something loose in your steering, minimize (or only drive back to the shop) your driving until a cause is determined.
Thanks for the replies. @Jsolo I think the fluid was low just from probably never having been changed or topped off since the car was built in 2010. I think @SonicVQ is on to something with the steering shaft being loose. I'm going to jack it up tomorrow so I can change and flush the power steering fluid easily so hopefully I can check some things then, but I'm definitely going to call the shop Monday to say something and bring it back in.
AdamBritt (02-22-2020)
No real flushing suction out as much atf fluid out of ps reservoir with turkey baster and refill with atf fluid. Do this again a week later. DONT USE PS FLUID OR PS LEAK STOP
Just say no!!!!!
I never had good luck with turkey basters. I use a medical grade syringe to suck out as much as possible. Refill to proper level, start car, turn lock to lock slowly several times. Repeat. I think it took me 3 such cycles to go through a quart of fluid. Also, I had card board under the wheels to make it easier to turn.
Garage called me a little bit ago and said the steering rack was loose and had about 1/8" of play in it. After tightening that he said it feels better so hopefully it'll be back to normal for me tomorrow.
When I was researching this problem initially I did find a lot of discussion for how to flush the power steering fluid I have a little hand pump for bleeding the brakes that I'm going to try. I'm hoping the tubing will be enough like a syringe to get in the corners of the reservoir but we'll see.
If you look at the steering rack below the driver side, you will see a big bolt on the steering rack all you have to do it tighten it a bit until you feel pressure from the bolt. It will reduce the play in the steering wheel and make it more direct. Just do not over tighten it, I did mine 10k miles ago and turned the bolt by 1/4 and the steering wheel feels amazing and no issues at all.
I doubt it. When I got it back in it was two weeks after I picked it up and they were nice enough to get me on the schedule the day when I called. They got it done the same day so I'm sure they only tightened the steering rack bolt that Said Amir mentioned. There is still some looseness when turning to the left but it's barely noticeable especially compared to before although it still bothers me. I am thinking about calling the local Nissan dealership since they would hopefully know what to look for and maybe they can do an alignment since my guy doesn't and the wheel is off center to the left a little when cruising straight. I had to pack up my garage due to moving out so I don't have any tools or place to do a more thorough check myself; hopefully I can find a place soon.
kroy
10-21-2017 09:39 PM
