Moog Sway Bar Endlink Fitment? AWD Sedan
Should I schedule a return for mine? 3/4 are like this. Out of the box they were super bent inward and when I bent them back to straight it left a gap between the boot and bolt. I知 thinking grease will be able to escape from this.
fill it up with some grease it should pop the sides out. Or pull it up with the finger nails if anything. If it is just not working you can apply some heat onto it to soften the rubber to place it in its place or return it and get some replacements. I had to get a replacement because one of them had a big tear.
mjnoles1
12-18-2015 10:19 PM
