Suspension Refresh
Suspension Refresh
I am planning on replacing some wear items soon. I was thinking of the Tein Coilovers and then getting other wear parts at the same time. I have a G37s with 164k, what parts do you recommend getting? If I lower the car by an inch or less, would I be okay going without camber adjustment?
I wanted verification. What do you recommend for replacement bushings? I saw some hard bushings for sale. Makes me wonder how much more stiff it would ride. I would like to get some poly bushings if available, the only issue is the squeak that could go on. I would like to replace the bushings on my sways to poly as well. Concept Z Performance has some nice parts.
If you're thinking Tein Basis coilovers, I made the same choice and have never once regretted. Amazing price, OEM-like ride quality and the drop range isn't too aggressive. It would be in your interest to get camber kits if you're replacing suspension and planning on lowering more than an inch down the road regardless. I suggest dipping into the numerous coilover/camber kit threads so you can get a lot more opinions.
ezbme (05-08-2017)
