Rear non sport caliper won't fit around rotor
Switching out my rotors and pads. Done this a handful of times on other vehicles. I can't seem to get the rear caliper in the correct position go go back on the rotor. The one not touching the piston seems to be sticking too far out
100%? Probably not. I ordered the rotors and pads from a company on these forums. Pads are posiquiets and they seem to look just likes ones I took off rotors look like ones I took off. It's just that front pad that doesn't touch the caliper, seems to be sticking out too much.
Your pads are not put in properly. The outside one needs to go in further. There is probably a retention clip not in place properly. Take the pads out and you can see where the rotor would sit in the caliper.
This is of course, if you are using the correct parts and not the sport brake rotors.
not sure what the issue is but if it where me I would remove the rotor and install the caliper back on the hub. Then try shifting the pad back over to clear. Looks like everything is shifting towards the car side and moves together as a unit.if you can get it to move towards the outside then remove it install the rotor and try the caliper again.not sure if this would help but it would be my next step to try since both pads are more closer to the car not just the outside one.
