Spring and camber kit
I am pretty sure I want lowering springs and from what I have heard I should get a front and rear camber kit. Does anyone offer springs and camber kits for the G37 in a package? Maybe save a little money.
Basically whats the cheapest way to lower my G without killing my tires and getting something that's a piece of crap?
With a mild drop spring like Riccio mentioned you should be Ok in front, I would recommend a rear kit though. The 4 bolt camber/toe kit is about $50, teh rear 2 bolt (toe) and camber arms are about $180. Both setups will get your rear camber/toe in spec.
The front tow is easy to spec through the tie rods.
J Rad
04-08-2016 07:49 AM
