Need bit of help staggered on X
Old 07-11-2015 | 08:47 AM
tscani's Avatar
tscani
I'm planning to staggered my 09 g37x I was wondering if these tire size would okay for x front 225/35/19 and rear 255/30/19. I got Diameter Variance -.70%? from tire size calculator and have no if its okay for my x..
Thanks
Old 07-11-2015 | 09:34 AM
Thanks
What wheel widths are you running?
I'd stick w/ taller tires that are closer to stock rolling diameter.
If you want to run 225/255s the 225/45/19 front 255/40/19 rear will give you a great 0.22% variance and you'll be very close to OEM diameter too. The sizes you listed would result in about 6.5% shorter than OEM, not a good idea.
Old 07-11-2015 | 10:17 AM
tscani's Avatar
tscani
Thank you.
You always provide great answer to all my questions )
Thinking about getting 19x8.5(1.5" lip) 19x10(2" lip) roughly +48 offset
Old 07-11-2015 | 03:08 PM
Thank you.
With those offsets and widths I'd run more tire, a 235/45/19 & 265/40/19 will only be 0.07% variance and fill the fenders a bit better. A 245/40/19 & 285/35/19 will be very similar to my fit, as long as those offsets you listed are correct
tscani (07-13-2015)
Old 07-11-2015 | 08:00 PM
tscani's Avatar
tscani
Thanks again.
I just got some other answer from friend of mine. not sure if he is right or not...
"I believe they would be ok on a awd because the tire size is so close in diameter(.7%, 806 revolution per mile and 800"( front 225/35/19 and rear 255/30/19)"staggered fitment as long as tires are near the same diameter it doesn't matter"
it seems like you both have right answer and I'm bit confuse now.... lol
please help
Old 07-11-2015 | 08:19 PM
G37xhibeet's Avatar
G37xhibeet
225/35/19 is gonna be >6% smaller than your OEM 225/50/18. If you wanna run 225 up front (I highly recommend 245 though) you should use 225/45/19 like Newt said. A good rule of thumb is for every 1" increase in wheel diameter drop 5 from your tire profile, given constant width. Having said all that, I'd go with Newt's recommendation of 245/40/19 & 285/35/19.
Old 07-11-2015 | 08:41 PM
Is there a particular reason you want to run such short tires?
Having your new tires so much shorter (over 6%) is not something I'd recommend.
The front to rear variance is critical, but going so far away from OEM diameter isn't something I'd want to gamble with.
Old 07-11-2015 | 08:50 PM
tscani's Avatar
tscani
Thanks all
There is no particular reason... I just found real good deal with those set up...
After reading all these reply i should go with what you guys recommend.
Again thanks for answering nooob question )
Old 07-11-2015 | 09:35 PM
Thanks all
It's not a noob question, tires and particularly tires set up for AWDs can get pretty confusing and it's easy to pick a combo that will cause issues. Always best to do research and ask any questions prior to plunking down the cash.
Old 07-21-2015 | 11:27 AM
NickD's Avatar
NickD
My stock 18" 370z wheels might fit. They are painted gloss black and have tires with about 90% tread.
Old 07-21-2015 | 12:01 PM
i heart ricers's Avatar
i heart ricers
Thanks
someone should take all these "staggered on x" threads and put them in 1 section
Old 07-22-2015 | 09:54 PM
RxRyanM's Avatar
RxRyanM
Like the brakes, suspension, wheels & tires section? You're right. Good idea
Old 07-23-2015 | 09:23 AM
i heart ricers
brakes?
suspension?
all i see is "staggered on x" threads
fuzzed
08-21-2020 10:35 AM
beng37s
12-08-2019 02:21 PM
Kojack
10-09-2015 06:53 PM
faze2988
10-07-2015 01:05 AM
