Fortune 500 Coilovers and Camber Plates
Hey. I drive a 2010 Infiniti G37x Coupe and am looking to buy Fortune 500 coilovers. I plan on dropping my car about 1.9" in the front and 1.6" in the rear. This car is my daily driver so I don't want to run too much camber. About how much camber will I be running with this set up and do you believe that I will need the camber plates or a camber kit?
If camber is an issue, I saw something online about SPC camber bolt. Would I need the whole camber kit, or can I utilize just these bolts so I'm not running too much camber?
SPC Performance Camber/Toe Cam Bolt Kit; Pair, Reqr's 1 per Wheel INFINITI G35
Our cars don't use camber plates, just front adjustable A-arms and rear camber arms or the wider range bolts
The fronts aren't adjustable but have a pretty wide spec range, dropping almost 2" in front will put your camber over -2 so I'd recommend the front kit, the rears will be just under -2. you can get by w/ the rear camber bolt/rear toe bolt kit, you need two of these kits, costs about $50 here~
blnewt (05-04-2015)
i tried searching for a DIY but couldnt find any. Could you point me to the right direction.
Thanks.
http://www.spcalignment.com/instruct...62-INS_WEB.pdf
mmnjtwa
09-07-2015 02:27 PM
