#676
Try these Nismo S-tune 19x10+30 on 255/40s these are a sick deal if they are still available~ https://www.parts.com/index.cfm?fuse...2DD03001EA2610
#678
Running stretched within reason is fine, many run 255s on 10.5s without issue, and it depends how you plan on using your car. If you want to do some track duty it's best to have tires mounted within the tire's recommended wheel width range. I'm running 245s on 9.5s and they've been fine and I do push the car pretty good sometimes, but not a track day yet. Unfortunately 265s aren't a very common size, if the tires you like are available in that size that would be a good choice over a 255.
#682
Is it the look you don't like or something with grip and traction? Blnewt i daily drive my G37xS but this setup will be for the spring-summer season where its mostly sunny and dry. Mostly city driven but i often go for hwy and scenic cruises if that would help you give me any other advice. Thinking of grabbing some PSS's or maybe pirelli's/toyo's?
#683
Awakence (10-25-2016)
#684
Hey folks I'm in need of advice, I have 19x8.5 +30, I believe I'm running 2454019, I'm looking for a more aggressive stance with the wheel I have, the question what size spacer should I run or is that even an option. Thanks in advance
StarKiller (11-25-2016)
#686
#688
I'm planning on getting the SSR GTV01 Wheels in 19x9.5 ET35 on my 2010 G37x coupe. Will I be okay without a camber kit? I kind of don't have the extra $500 for them at the moment. If not I'm going to go with them in 19x8.5 ET25 instead.
#689
