#513
The Steering Wheel Guy
Ok, here it is what I hope to be my last question on my planned squared setup:
Going with 18x9.5 ET34 wheels; so thinking about tires, specifically overall tire height.
Calculators have me at stock: 682 mm (I'm on spacers, so tires look almost flush)
So if I play with width and sidewall height:
265/45: 696 mm. Maybe too tall, but now the wheel is tucked so it might be ok.
265/40: 669 mm. Shorter than stock
275/45: 705 mm. Way too tall.
275/40: 677 mm. This might be it, perhaps 5 mm spacers for the flush look. Worried about the fit on the front.
285/45: 714 mm. Nope
285/40: 685 mm. Right height, not sure about the fit on the front... or back.
What would be the optimal tire size?
#515
so i've pulled the plug on some Work Emotion D9Rs 19x8.5 +30 for my g37 sedan to clear akebonos too, just wondering which size tires would be the best fit on stock height, 245/40 or 255/35? currently on 245/45/18 and that fills up the guard a bit better than 245/40 i believe
pic for reference:
pic for reference:
#519
19x10 35
After owning my x sedan for 3 years, and doing a lot of research I finally signed up and doing my first post.
I think I'm getting close to the setup I'm looking for. I like the way sedans sit with eibach pro kit, but they're just not the same on the x. So I opted for ksport coilovers to get close to that drop as possible. Then I was looking at wheels and I'm thinking 19x10 35 but don't know what tires would work be with that wheel size. Wheels I'm looking at are the str 607, I like the concave look these have.
#521
Will 275/30r20 tuck on air???
I have a bagged g37 coupe on Vossen cv7's 20x10.5 +25 all around. Right now I'm running 255/30's and it tucks with absolutely no problem, had my front fenders completely rolled. But it's more stretch than I want (especially where I live the roads aren't that great) I'm looking to get 275/30's because I want maximum tire on the road but still be able to tuck when I'm aired out. Anybody have a bagged setup with 275/30's that can give me an answer? Or anybody that will have a 100% yes or not that it will tuck or not.
Thanks
Thanks
#522
Do you think 275/30/20 would tuck on air? I currently have 20x10.5 +25 all around on 255/30/20 and I didn't want to have this much stretch. I had fender work done so that's not a problem. I'm looking to get 275/30's because I want maximum tire on the pavement but still be able to tuck when I'm aired out.
#523
You could go 265s all around just to be sure.
Might even post your question in the hellaflush thread~
https://www.myg37.com/forums/wheels-...sh-thread.html
