#482
For your coupe go back to Simpsons G, he's running 275s on 10.5+25, so you'd have 3mm less room but 10mm made up for in tire width (with the 255s) for a net 7mm gain at the fender. IMO that should be a good fit. If you want to push it closer 265s would be 2mm inside Simpsons depending on how wide your brand tires actually run
https://www.myg37.com/forums/brakes-...ml#post3891573
Shane D (03-23-2019)
#483
Is everyone running out of spec negative camber with any offset less than +25? I'm seeing some crazy small offsets and using an offset calculator they all appear to stick out quite far. Based on my stock setup with a 20mm spacer, I'd be best with a +38 offset on a 9.5" rim.
I'm seeing 10" widths with a smaller offset and I can't imagine how that would work without some serious camber.
I just want to run 9.5's all around and wouldn't want them any further out than what I have now with the 20mm spacers on stock IPL rims.
#484
#485
The Steering Wheel Guy
Thanks, I appreciate it!
#486
On a coupe, a +25 is pretty aggressive in the rear. You basically have no chance of running a full size tire and in spec camber. I had a 10.5" +25 setup and had to run a 255 in the rear to keep my camber in spec. It still rubbed the fender liner, but overall it fit. I wasn't fully satisfied with the fit. I couldn't imagine running an even lower offset on a 10.5" wheel. I currently have 19x9.5" +25 all around and that's a better look in my opinion.
#487
I'm sticking to a 9.5 in the rear but going by the offset calculator the size you currently are running would extend out 4mm further than what I currently have with the stock rim and a 20mm spacer. I can't honestly see running a setup that sticks out even a mm further than what it does now. A +30 in the rear would be pretty good IMO. But yours don't seem to stick out any further than my setup. I agree, your setup looks good.
#488
Yup...nailed it
#492
Originally Posted by Ozzie069
What you lowered on?
#493
My setup is as follows:
No Big Brakes. No Spacers. Everything I have put on is listed below.
2008 G35x Sedan
~SPC Front camber kit (72130)
~SPC Rear camber kit (72260)
~Fortune 500 Coilovers with Swift upgrade dropped from ground to fender: Front 67.4mm, Rear 68.7mm
~STR Racing 607 Rims 20x10.5 +35 offset
~Continental Extreme Contact DWS 275/30R20
~Gorilla tuner style lugnuts (21623sd)
2008 G35x Sedan
#494
