Help AirLift sleeve out of place
Has this happened to anybody with AirLift bags??
Its suppose to look like this
I've been trying to roll the bottom of the sleeve over the strut but I cannot get it to roll over. I hear a popping noise from the bag whenever I hit a bump. Does anybody know how I can fix this?
First question is have you called airlift for guidance? 2nd have you fixed this yet? Was it upon installation? I would think it would be best to remove the bag and deflate it and then infalte to max and see if that will work. It does not look safe to drive around on though IMO. I have seen a youtube video of a D2 bag doing the same thing and they fixed it, you can try to search for it and see if they mention how it was fixed.
What I think happened was that when I tried to jack up the front of my car I did not air out while it was on the jack and it probably overextended the strut. I also broke the front sensors on my Accuair e-level when I jacked it up too. Is there a proper way to jack up your car with bags and accuair e-level?
I'll try to look into how they fixed the problem of the D2 bags.
I have never had problems jacking up my car with the bags or e leveling system. I also usually air up higher than oem height to not jack as much. If you aren't driving it might as well send it in for warranty repair before it expires. Have you been told to air out when doing maintenance and raising the car?
Yeah, the guy that installed it told me i needed to air out when was on the jack, before the wheels were off the floor. But then again the guy that installed it did a terrible job with my install. I'm going to take it to a shop to have them look everything over to make sure everything else is ok. If they think I should get it replaced I'll just have them send it in for me while my car is at the shop, every time I try to DIY I either break something or the part doesn't fit back correctly... I guess you can say I'm not very mechanically inclined, but Ive tried haha.
BTW, does anyone know if this company does a good job with air installs, of if you know any good shop in the LA area?
Join the SWITCH STANCE MOVEMENT or You're just standing still!!! - Home
I was thinking either taking it to them or Evasive Motorsports.
I think the bag is holding air but I have a pretty bad leak in my system. My installer didn't seal my fittings right so I cant really tell if the bag is holding air completely. I can still drive with it though.
Yeah, my fronts lift a lot slower than my rears but my installer said that its because it takes a lot more pressure to lift my fronts so that's why its slower, that's just the way these bags are made. I don't really trust anything he says anymore so Ill ask when I take it to a shop next month and let you know what they say.
^ Where did you get your bags installed?
That's how I jacked it up the first time but my installer was telling me that the airlift struts extend further than the sensors arms when there is air in the bags and that's how I broke my sensors. It might also be because I jacked it up from one side then the next. Or he's just making up excuses to cover up his mistake of installing it wrong.......
if you have room for bags while driving around it shouldnt get pinched or snaged while jacking it up. As for your elevel sensors they should of mounted it to where your max high and max low will not cause it break. How are you supposed to put your car on a lift? Air up then down as they raise it? That doesnt make any sense to me. I've had my bags and elevel for almost 3 years, wheel swap often on jacks, and havent had any problems working on my car on lifts. Im not saying there is no truth to airring down to be on the safe side but i havent done it and never heard of it until this thread.
I was thinking the same thing also. I'm going to have the shop move the sensor lower when I bring it in. When the guy told me that I had to strap my wheels up when I jack up my car because the airlift struts extend further than the E- level sensor range.... I knew he was never going to touch my car again after that SMH. I should have listened to my gut and just took it to a shop to have it installed
So you guys air up, then jack up your car without airing out? What jack points do you use?
I use the normal jack points on the car where you would put the scissor jack and whatever that flat part is called going towards the oil pan. Keep in mind I have an M not sure if the front of the G has the same thing that's flat. Either way jacking up the car shouldnt mess things up. Just worked on my car today and had no problems using the combination of a lift and jack. I hope your car gets situated, sucks to have bags and accuair and not use it.
kevshiau (08-18-2014)
