Help fitment
fitment
I am looking to buy set of varrstoens es2s.
with 235 35 19 & 255 35 19 in the rear...
I currently have tein h tech installed and still deciding between 9.5 10.5 +22 and +12...
with out the camber kit, what offset should i buy with no rubbing issue???
Should be able to clear the front without that aggressive offset, how much tire do you want to run? I'd run 9.5s +22 on 255/40/19 Front and 10.5 +30 with 275 or 285/35/20. If you had a deeper drop on coils or S Tech springs the +22 in back would fit better but will poke some w/ H Techs.
I have spoke with rep from varrstoen and I have to go with +12 in the front to clear akebonos...
planning to run with 235 35 front and 255 35 in the rear.. if I give -1.9camber in the rear.. still woyld poke though??
If you like that style I'd look at SSRs, they're better quality wheels and should have better clearance for you
SSR GTV01 Black Wheels & Rims | Tread Depot
http://www.treaddepot.com/wheelsizes/gt01s.html
4DRZ
Engine, Intake and Exhaust
12
05-18-2017 11:25 AM
kinchi
09-25-2015 12:04 AM
