SPL Upper Control Arms on G37!!!
Old 12-12-2013, 09:55 PM
TVPostSound
TVPostSound's Avatar
Couldn't wait!! They arrived tonight!!DOMO
Review after alignment.
The following 2 users liked this post by TVPostSound:
G37Sam (12-13-2013), Presto (12-13-2013)
Old 12-12-2013, 09:57 PM
TVPostSound
FIY
If you're going to spend this kind of money, don't be cheap, buy new ball joint nuts and bolts.
$27 for both sides.
Old 12-12-2013, 10:13 PM
Received 4,943 Likes on 4,176 Posts
Very nice!
Old 12-12-2013, 10:27 PM
Nice. You are the suspension king. But what benefit can be obtained by replacing the nuts and bolts? They don't really wear out or get stressed do they?
Old 12-12-2013, 11:04 PM
TVPostSound
This is my 5th R&R,
1) Installed SPC arms
2) Reinstalled OEMs when bushings failed
3) Reinstall SPC replacements
4) Install SPC Upgraded arms
5) Today installed SPL arms.
Yes, they were worn, and had a slight bend!!
Yes, I torqued them.
I really should have installed a new set every R&R.
Old 12-12-2013, 11:11 PM
cv129
cv129's Avatar
Congrats! The alignment tech will appreciate these for sure.
Old 12-12-2013, 11:14 PM
TVPostSound
One caveat, I adjusted close to max, still too negative camber.
I have 2 more turns left. Will let Henry (Temple City Auto) check it on a Hunter.
This might not be the right product for extreme drops needing to restore to OEM camber specs.
Old 12-13-2013, 02:50 AM
G37Sam
G37Sam's Avatar
If he knows what he's doing.
Old 12-13-2013, 09:19 AM
TVPostSound
Mine does!!
Here's my previous alignment:
align-1.jpg?t=1354389997
Old 12-18-2013, 01:37 PM
OMG_ROTFLOL
OMG_ROTFLOL's Avatar
Is the alignment you listed with the arms set to max?
How much are you dropped? Pics
What tires are you running?
WHeels? Offsets?
Thank You....I am about to do the same on my G, and I would like to get it right the first time...
2008 G37s 583whp
Old 12-18-2013, 04:55 PM
TVPostSound
WHeels? Offsets?
2008 G37s 583whp
No these are my last specs.
I eyeballed until Saturday.
Looks like Ill be almost at the camber end.
With the adjusters equal, SPL tells me the arms have a built in 6 degrees of caster.
Dropped on Swifts.
The SPC arms were at the end also FWIW
Wheels and offsets have nothing to do with alignment.
Old 12-18-2013, 10:16 PM
Polar_g37s
Polar_g37s's Avatar
Man you must be pretty slammed if these arms can barely get you within spec.
Old 12-19-2013, 10:39 AM
redrover23
redrover23's Avatar
thanks for sharing...but it appears that those will definitely hit if you are low.
on another note, wheel specs do affect camber. a wheel with more negative offset will increase camber. it may be slight, but it will.
Old 12-19-2013, 04:53 PM
TVPostSound
They are lower than SPC arms, they wont hit.
It will decrease camber, but barely measurable.
Old 12-19-2013, 04:54 PM
TVPostSound
Nope, Im on Swift springs.
Quick Reply: SPL Upper Control Arms on G37!!!
