SPL Upper Control Arms on G37!!!
For those interested in the max alignment allowance on these puppies, here are some actual results by a vendor on a 370z (and confirmed by the prototype tester)
I am not sure if the vendor is in this forum or not, so I'm attaching a screen shot instead of linking to the sale thread.
Im looking at -2 right now, and have 1 maybe 2 threads left.
Going to alignment shop this afternoon.
My goal is to return to -1.
Ill take the +6 caster they preset in order to keep the neg camber on turns.
Looks like SPL took this into consideration.
OK we went with -1.4 camber and 5.9 degrees of caster.
Still have room to go. Dropped on Swifts these arms will put it in the OEM -0.8 sweet spot.
I don't believe they will fully compensate for a lower drop.
SPL did tell me that these arms are engineered for 6.0 degrees of caster with bolts being equal length, and that is true.
I love having extra caster, makes the steering tighter at high speeds, and get a little more negative camber on turns!!
Spherical bushings are the way top go! Better compliance in the front.
I still haven't found any downside to these arms.
Lt8Che
91
04-08-2022 04:55 PM
