Help SSR MS3 Disk Clearance ?!
I'm about to pull the trigger on a set of SSR MS3. I have the sport package so I have the Akebono BBk. I noticed everyone is running a HP Disk up front but I want to go for a bigger lip. With the MS3 being convex, is it possible for me to clear a MD?
I contacted SSR and they say it should be a tight fit, but should work, but no guarantees. Anyone here pull off a MD front and SL rear?
Size is 20x9.5 (-3) MD Disk
20x10.5 (+5) SL Disk
I have SSR MS1's in SL Disk on the rear, it requires a 3mm spacer to clear the Akebono caliper in the back. I'm running HP Disk in the front so can't really comment on whether MD disk would work but my guess would be that you might be able to pull it off just barely, if anything maybe have to run a 3 or 5mm spacer up front as well.
SON415
09-28-2015 05:49 AM
