Help:Rubbing Issues
Issue is soft springs and low offset. Get your self a set of KW V1 coilovers or NISMO S-tune suspen setup. They are for the 370z but will work fine on the G37. Or go with SWIFT springs and new OEM Sport shocks. All setup will run you over $1,000. But no matter what you do! your springs are the issue. I also am not a fan of shaving down anything on the car or cutting anything!
See people don't understand that when you change the size of your wheels and tires from what Infiniti designed into the car you need to also upgrade your suspension as well.
When you mod a car you want to find a good balance between OEM and aftermarket. Most just mod to be cool or to fit into a group of others, because they just follow what everyone else is doing.
I did a light mods to my IPL and the car is perfect! I only took what was there and made small enchantments to the car to give it edge!
considering how the bumper tab is a known issue with the coupes and rubbing, i dont see why it isnt worthwhile for the OP to investigate it with his sedan. it takes less than a second. the gash on the tire that looks *exactly* like the damage the bumper tab can inflict. it's steel after all.
http://lmgtfy.com/?q=myg37+shave+bumper+bracket
Yea, Took it back to the shop and they ground down the bumper bracket and also removed some of the felt liner.
I still rub on some large bumps but, 95% of the rubbing has been eliminated. Will be ordering coil overs pretty soon.
delfinparis
11-16-2015 02:26 PM
