Help Bent suspension? Rear wheel sitting too far out, toe in issue !
Hey guys, i have tried the search button, didnt really find anything related so here we go,
i have a 2009 g37s coupe 6mt, Stock suspension, no modifications.
i noticed that my rear right tire sits about 0.75-1 inch further out as compared to the left (looks like i have a wheel spacer on but i dont). there is an excessive amount of inside wear on that tire so it tells me there is a toe in issue. then i checked the wheel gap and the entire wheel sits further towards the back of the bumper (0.25-0.50 inches) as compared to the left (as if the caster of the wheel moved).
i have factory warranty till sep 30 2013, i brought it to the dealership (legacy infiniti of long island NY) and even though i pointed all that out and showed them that anyone with a set of eyes can see that there is something abnormal about that, the dealership said "there is nothing wrong with your car, everything measures perfectly." to my knowledge you have to drop the rear sub frame to even check the suspension and if a spring bucket, spindle or a control arm is slightly bent, you cant see that with your bare eye, but im sure they didnt do anything except pick it up on the lift and look at it and called it a day.
long story short, what can i do about this? i am going to try a more reputable dealership that arent full of idiot techs which ignore the obvious. what can be bent that causes the wheel to have a castor effect towards the back of the car ? what can cause the toe in issue ? any advice would help. vehicle only has 41k miles on it and no i didnt hit anything, i checked pictures of the car from day one and it was like this when i purchased it.
I presume the car was pre-owned when you bought it? If so, was it wrecked at one point? If the whole unibody got shifted, you could see such an issue where the suspension components look fine. Hoping it wasn't wrecked and had a shoddy repair job. Do you have any pics that you can post?
If purchased used do a Carfax...
If they fixed it under radar then it wont show on the carfax if it was wrecked or fixed...
If purchased new or used call Infiniti USA CS... they will note it and get it handled correctly ...
lastly pay a lil and get it aligned ... aside from Infiniti a good shop will tell you if any damage was there... yet too will show how much Camber yet toe difference there is R vs L...
Good luck
Good luck
Good luck
Good luck
Honestly..not to be harsh but the techs are idiots. I had to personally tell a tech how to fix my tpms problem the first time, I need to know possible things that can be bent in the case that it was not in an accident this way I can bring it to the attention of the tech since he is oblivious and beyond useless.
Took mine out and running fine without a kit but just a toe bolt...
Whaaaaat... thats Camber \ not Toe LOL.. thanks for the pics yo see OP... toes are in or outward tires on independent suspension like ours... camber arms bent... kit needed but be cautious... putting a kit in some will push the wheel out and will need to run Neg more...
if you're using ascii pictures:
\ is negative camber if you look at the tires from behind the car
\ is toe in if you look at the tires from bird eye view
I took it to a diff Infiniti dealership they said they got it a little straighter but they can't fix the caster issue and they are still checking to see what is causing that caster problem. Something is bent and the dealership said there is no signs of the body being bent so that's good. But what else.can be bent that causes the wheel to caster towards the back bumper. It's closer to the back then it is on the driver side. Look at the mud flaps in the first 2 pics. U can tell the difference in distance that its sitting.
Yes Juju I'm agreeing with you...camber is real easy to see by the eye... Toe pitch is harder to see unless its way WAY off ... the angle of his tire in the pic is camber \ line illustrates the way his tire looks to me in the pic... some camber can go / where the tire is out in top pitches inward ... his does what most do running neg not pos... --- that would be his tire toe would be a angle which he would feel a pull left or right... pending if he had a toe issue ...
Good Call ... I still have my Spring Bucket though I dont ise it... being on true coilovers eliminates that bucket... but I'd rather leave it for me just due to lease and when time comes less parts to switch out...lol
Wonder if that bucket has a crack or bend... they'd have to remove it to see... I've heard in the forums of one G hitting a pot hole smashing that bucket...
Good call blnewt...
I honestly think it might be the spring bucket, but what else can be the issue ? Sorry to dbad mouth a dealership but the guys at legacy are nasty. I told them today that Manhattan found an issue with it and upon looking at it they knew there was an issue. the answer I got from the manager was "well they didn't tell u what the issue is, my guys looked at everything and they couldn't find an issue" ...I'm sorry but that is not the proper way to handle things especially since they sold me the vehicle like this and their techs didn't know how to diagnose and fix a simple tpms sensor.
Hence is why I need different opinions on what might be bent. this way I can have the techs pay specific attention to it. These dealerships are freaking ridiculous. My car has been in the shop since last wend. And today I been told that this isn't covered in the warranty.
I'll post updates on what's going on.
arm, bent, camber, crooked, dealer, g37, independent, indipendent, rear, sold, suspension, suspention, tiire, tire, wheal, wheel
