Another G Sedan Going Air
Old 04-30-2013, 02:21 AM
808MIKE
808MIKE's Avatar
Originally Posted by 07 Ivory Pearl
Thanks man and congrats! Yeah can't wait to get this done. Post a pic of your car aired out. I was debating on using AirRex struts.
Cool Bro..Here's mine Aired Down..Front Only goes so much till the Upper arms hit the Strut tower...and I'm still playing with the Tuck in the Back!
07 Ivory Pearl (05-22-2013)
Old 04-30-2013, 02:23 AM
808MIKE
808MIKE's Avatar
Originally Posted by Kinkbmxrydr
how much was your set up?
Complete kit was $4700. was supposed to be about $5200..But I got hooked up with the right Peeps!
Old 04-30-2013, 11:46 AM
fairladyz34
fairladyz34's Avatar
final product should be cool, hmu if you have any bag questions. I had the black bagged g37 and i did quite a few shows with it in NJ so chances are you might have seen it last year...
Old 05-16-2013, 02:30 PM
kevshiau
kevshiau's Avatar
Does anyone know if it would be better, performance wise, to put bags over my KW's or buy AirRex struts?
Old 05-17-2013, 09:13 AM
07 Ivory Pearl
07 Ivory Pearl's Avatar
AirRex is basically a coilover with a bag in place of the spring. All you need to do is call KW find the size of the shock body and then call UAS (universal air suspension) tell them size of the shock body and they will set you up with a slip over bag for that coilover fromt the AeroSport line. For the rears if the car came with a detached spring then a cup style bag will be used and if your car is setup like the front then you will get a slip over bag for the rear. If the rear had a detached spring and the coilover you have now uses an adjustable spring on the shock you will still go with the cup style bag as if it was a detached spring.
Did some trunk work last night. Using 1in thick wood. I am making one more cut in front of the tank to get to the spare wheel. Going to mount the air compressors above the tank for more room.
kevshiau (05-17-2013)
Old 05-22-2013, 10:43 AM
07 Ivory Pearl
Temporarily installed my Kuda Cell Phone mount with Accuair Switch Speed. I installed counter sunk magnets and screwed them to the corners (made for permanent installs) and epoxy square magnets on the underside of the mount so I can use the wired remote in the car or outside of the car. I didn't run the wire just yet but will be doing so soon when I install the Digital Air Pressure gauge. I will have the entire car wired for each corner and tank shortly. The gauge will be functioning just throwing error codes till the sensors are connected to the manifold and pressure in the tank. I was going to do a permanent install on the controller (and I still can) but liked the idea of having it able to detach. They also give you a ton of slack to hit switches outside of your car. I will have most of the slack tucked inside the dash except for a few feet that I will spool into the space of the mount.
Old 06-04-2013, 08:07 PM
07 Ivory Pearl
Another update I installed the Stance coilovers and slammed it. I ordered the propper bags and brackets for the front coilovers which shall be here Friday and the rear bags my buddy will be getting when the final install goes down in July which will be cup style. In the mean time I will be static and setting my trunk and wiring everything up and just getting it all ready for the lines and bags. Some pics of her slammed on my old rims I had for my 07 Altima.
Old 07-29-2013, 07:16 PM
07 Ivory Pearl
Just a little update the car is in the shop getting the rest of the air ride put in. Here is a teaser pic of the rear along with my last mock up of the freshly powder coated tank/accuair exo mount and compressors.
Old 07-31-2013, 05:40 PM
viet2100
viet2100's Avatar
Nice! By the way, the arms are only $15 to replace. If installed correctly, they will be fine. I have installed these on a sedan and a coupe (IG usernames: @v36boss @swg37stout)
Updated e-Level Sensor Arm - OPEN ROAD TUNING
Old 08-08-2013, 11:55 AM
07 Ivory Pearl
Shes all bagged up. Picking car up hopefully tonight or tomorrow.
Old 10-16-2013, 10:27 PM
sicko
sicko's Avatar
Nice! Congrats...
Old 10-24-2013, 01:03 PM
07 Ivory Pearl
Thanks! Here's a few pics of the completed setup. Tank and mounts (minus compressor shelf) are powder coated white with glow in the dark blue powder int he clear. Hard to get a shot of glowing. I also mounts 3ft LED strip to to make everything pop. I have the 6 disk changer in the trunk which hides my one compressor I will be eliminating this shortly after my 2010-2013 non-Sport conversion is done. (I like the non-Sport the best bc it resembles 07-09 Sport with added fogs).
The last pictures shows the glow in the dark powder in the clear with a slight hit of light charge t it. I have UV LEDs that I will be hidden but aimed at the tank to enhance the glowing of the tank when the white LED strip is off.
Old 11-16-2013, 04:00 PM
R3diK3r0u5
R3diK3r0u5's Avatar
I want to see more pics!
Final update of all the finished products please, let's see the clock gauge installed!
Old 02-26-2014, 03:16 PM
  #29
07 Ivory Pearl
Sorry for long awaited update pics.
I will be getting new and more aggressive wheels. Also I got my new License plates installed in this pic.
Some pics of the clock air gauge. The silver button when pressed gives my my tanks air pressure. The OEM buttons on the left and right are dummies and non functional.
Old 02-26-2014, 03:22 PM
  #30
ChinkyChoy
ChinkyChoy's Avatar
looks real good cant wait to see the new wheels
where in jersey are you?
Quick Reply: Another G Sedan Going Air
