Eibach pro-system-plus kit Anyone have this kit?
Can anyone that has this kit give me any info on ride quality compared to stock, how much it lowered the car and just over all how you like it? Or does anyone sugest any other brand kits. I was just looking at the eibach kit because everyone reccomends there springs for the perfect lowering height for filing the gap between the finders and tires.
http://m.eibach.com/products/pro-system-plus.shtml
The Swift lowering springs will be a bit more compliant than the Eibachs and probably the closest to stock ride comfort, drop is similar. Here's a few info threads~
https://www.myg37.com/forums/g37-sed...d-sedan-2.html
https://www.myg37.com/forums/g37-sed...th-review.html
https://www.myg37.com/forums/brakes-...lled-pics.html
Another Swift Springs Install (RWD Sedan) - MyG37
Eibach Mobile Phone
Eibach Mobile Phone
Try the Koni Sport Kit, which os H&R springs wrapped by Koni FSDs.
My recommendation is Swift springs on Koni Yellows.
I agree with HD about the ride feel. In fact if anything they're a little nicer than the stock setup except on real bad roads. Works great on the track and the drop is just right. Not too much on the front or rear and it maintains the same geometry of the rear being slightly higher than the front as in the stock setup which I like. I would also recommend a good set of sway bars (either the Eibach's or Hotchikiss) to reduce your body roll and then you'll have a great setup for most any condition. Good luck.
Al
Al
optikol
01-28-2016 07:31 PM
RexHavoc
10-02-2015 11:47 AM
