Suspension/coil over question
It seems as though my vehicle's stock struts are getting a bit long in the tooth, and lazy in their old age so they need to be retired. I've been searching the net and the forums for the past week and am having a hard time locating the information I am looking for, so hopefully someone here can help. I have an 08' sport coupe and really like the stock suspension, so I would like to target the same level of suspension in terms of dampening and ride height but I'd like a suspension replacement that will last longer. I'd be comfortable dropping slightly but not a whole lot... At the most I'd just like to tightest up the wheel gap without the look of the car being lowered. I'd also be okay with going a tad stiffer. What I'm really after is preformance and longevity. Most of the coil overs I've found seem to drop the vehicle significantly which I'm not interested in, but they seem to have the preformance I am looking for. The only coilover product that I've found so far that states it can maintain factory ride height is the Megan Racing Street LP solution, but I can't find anyone who can comment on the quality and preformance of that product. I'd rather not get OEM parts because they cost nearly as much, but I am tempted to. The other part of my quandary is the fact that I have 4was and several sites explicitly state that their products are only for non-4was vehicles, so that muddies the water even further. To date I've always stuck to drivetrain work and left the suspension alone so I'm a bit green in this area so any advice you guys could give me would be greatly appreciated. I'd like to stay in the 1k-1.3k range. Thank you!!
I don't think you'll get anywhere near stock height w/ Megans though, the fronts you can go as high as a 4x4 but the rears are about 1.6" drop at the highest setting. Mine is a sedan so the coupe may be a bit different but probably pretty close in drop. If longer springs are available then you could go higher as there's plenty of threaded adjustability front and rear, it's just w/ the shorter spring you're starting out pretty low. Might want to contact Megan personally about that issue. Might even be able to put Swift springs that may be a bit longer for the height you want. Member Soundmike did this to his BCs, he might even have those springs for sale
If you want a slightly stiffer spring you might want to go w/ Tokico or Koni struts/shocks and 370Z springs, should give about 3/4" drop.
Where would I get those Mike?
Oh, and OP, might want to look into BC Coilovers as well, Soundmike dealt w/ some different spring setups that might work on your G.
In your situation (wanting a ride close to stock height) I'd definitely contact the company(s), they may have different options w/ spring setups to get you closer to what you're wanting.
The Megans & the BCs out of the box will be low out back (at least for the sedan).
HTHs
HTHs
gdaelemans
09-15-2015 12:20 PM
