Help! Winter tyre/rim fitting & sizes
Hi,
I recently got a 2008 G37S with 19" rims and high performance rubber... but I also got thrown in a second hand set of 17" infinti alloys (i think from a g35) with winter tyres fitted to them. The only thing is that all 4 winter rims are the same size, whereas on the rims currently fitted to my car the rear rims are wider than the front ones. Does this matter? Can I still use these narrower infiniti rims on the rear?
Thanks
BM
Thanks
BM
Just say no!!!!!
I'm not sure the fronts will clear the brakes. When I was shopping around for winter tires, according to some posts here and tirerack, 18" was the smallest that would clear.
It's easy enough to jack up a corner of the front and try fitting one wheel to see if it seats or not.
