Modme's OEM Bracing Project
#106
Purchased a set on Ebay and got these installed.
081B7-0455M is a thru bolt and can be subbed for any Class 10 M10 50mm Long Bolt. I used what I could find at Ace hardware, an M10x1.5 50mm Long Bolt with 2x Washers and Class 10 M10x1.5 Nut(per side). For the bracket side an oversized OD washer would be beneficial but not required.
11298-CA015 is an M10x1.25 bolt, I used an extra trans mount bolts that I had leftover from the Junkyard that fit. But a bolt that is at least 25mm long is good.30mm will work as well as the cavity is pretty deep.
You can get all the hardware for <$10.
Thanks Modme for this info!
@thescreensavers Are these front suspension member stays performing a similar function as the Cusco Front Power Braces?
https://conceptzperformance.com/cusc...fs_p_38324.php
I have the Cusco rear power brace installed and it made a noticeable difference.
#107
This thread won't leave me alone. Planning on doing the "Z" braces and possibly the front 370z Nismo/Yamaha damper later this year.
For anyone who has done the Nismo/Yamaha damper, are there any bolts that need to be replaced or does it bolt on?
GTMTTG37
04-12-2016 08:29 PM
2009G37Bandit
01-10-2013 02:46 PM
