Increasing wheel offset
Old 11-14-2013, 11:43 AM
Tunerz_Store
Parts Specialist
Tunerz_Store's Avatar
It will get the wheel closer to being flush.
8" wheel +40 is only 3mm difference which you probably won't even notice.
I assume the car is daily driver, so going with a staggered wheel setup is not going to allow you to rotate the tires, so that only leaves one recommendation.
Old 11-14-2013, 01:16 PM
MADDSLOW
MADDSLOW's Avatar
So I'll go with the 19x8.5 +35 with 245/40/19 all around.
Thank you VERY much for your help!
Old 11-14-2013, 06:15 PM
Received 4,943 Likes on 4,176 Posts
Good choice, the 245/40/19 is the best tire choice for a plus size on an X, well under 1% diameter from OEM so everything will be well in range
Old 12-07-2013, 04:51 PM
MADDSLOW
MADDSLOW's Avatar
Put my Enkei Raijin 19x8.5 +35 wheels and 245/40/19 Bridgestone Potenza RE970AS tires on the car and it looks great! Thanks again for the help!
helloandchau
10-06-2015 05:26 PM
xpcgamer
09-07-2015 07:10 PM
ZachThomas
09-03-2015 01:40 PM
Quick Reply: Increasing wheel offset
