Is caster adjustable on a G37 sedan?
I took my car for an alignment and the shop is telling me that the caster is not adjustable on my car. I do have front and rear camber kits installed on my car and another shop that I have been to was able to adjust the caster. On a stock G37 is the caster adjustable? Is the caster also adjustable if you have front and rear camber kits?
Rather than starting a new thread I decided to bring this one back up. Originally I took my car to NTB in my town and purchased the one year alignment warranty. These are the people that told me that caster wasn't adjustable.
So yesterday I took my car to another NTB about 30 min away. They knew that I have a camber kit and they told me that the warranty doesn't cover aftermarket parts and the there would be a labor charge to bring everything back to spec. I had them do it because they would adjust everything. They finished roughly 20 min later. I paid and left, I didn't look at the alignment sheet until I got home and that's when I realized that they didn't even adjust the camber or caster in the front. They also gave me a sheet saying that "The manufacturer does not specify front camber and caster adjustments."
Do you think I have any recourse seeing that the first NTB sold me a one year alignment warranty probably knowing that my car is modified and that the other NTB charged me for an alignment and really didn't do anything?
That alignment is horrible! If your car had the camber arms on it when they sold you the 1 year alignment then they either need to continue to align your car per the agreement they sold you or refund your money. They can't have it both ways. If it were me I'd get a refund because what they sold you is useless if they refuse to adjust it for free like you paid for.
Your car is aligned worse now than when it went in. They did not adjust your front camber or caster at all (even though it is in spec on one side and very close on the other) and made your front toe worse on BOTH sides! They also took your toe from in spec to out of spec on one side in the rear. There's no way you should let that go. You just paid them to make your car worse. If they don't know how to adjust your alignment with the SPC parts they shouldn't have taken your money to do it.
Get your money back from them and go somewhere else. I have had an issue with NTB as well. Same deal, I paid for 3 year alignment and when I went in to get it realigned after lowering it more they said they wouldn't align it. I told the manager when I bought the alignment that I have coilovers and may adjust them from time to time and that's why I wanted the 3 year alignment, so they could fix it afterward. He said no problem at the time, but then gave me a different story when I went in to have it done. Long story short, I raised hell and he shouldn't budge. I called to his district manager and the next day I get a call form the manager of the shop. He aligned my car and refunded my money. He was not happy. Screw him, I tried to reasonably get him to do it the easy way without calling his boss and he wouldn't. I've been to 2 in the Houston area and both were manned by idiots. I'd suggest going elsewhere.
Just say no!!!!!
I don't think a place like NTB is proper to align this type of car.
There's being in spec, and there's preferred alignment specs. The first means the values are between range x-y that the manufacturer has specified. Preferred otoh will give you better handling, stability, etc based on the type of suspension mods you have. IIRC there are some threads on here where others have specified what those may be, but you'll have to do some searching to find them.
Agreed. The shop i work with know me fairly well now and always asks how i want the alignment set, they even recommended i get the aftermarket kit to help them with the adjustments. No additional charges, they kept their part of the "lifetime alignment" bargain, and i just keep doing business with them.
I think I'm going to go to Texas Track Works/PTP in Fort Worth. I know that they have experience in modded cars. They do charge a bit more than NTB, but at least they'll make all the necessary adjustments to get what you want.
I've contacted corporate for NTB, I'll see what they will be doing if anything. All I know is that they lost at least one customer for life and I will no longer be recommending anybody else to go to them for anything.
Here is a follow-up:
NTB called me back and directed me to go to another store near my house. They got the car back to factory specs without any issue and they also said that they would continue to honor the alignment warranty. They also said that they would work with the regional manager to get my money back that the other NTB charged me.
I wound up getting a call from the other store and in the end I got my money back and the guy that charged me didn't sound to pleased. The manager of that store was trying to defend the charge by saying that by having an aftermarket suspension I voided the alignment warranty. I guess they were wrong.
next time do check the piece of paper they give you after the alignment and make sure everything is adjusted to within spec. its an important piece of paper.
I never pay till i see it and ensure its been done right.
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
