Lug nut options/opinions
Old 03-03-2012 | 10:13 AM
SwissCheeseHead's Avatar
SwissCheeseHead
Hey guys. I bought just bought a set of WedsSport SA-55M (from kosstick) and I was looking for opinions on what kind of lugs I should get for them. If you have pics, definitely post them! Should I go with extended? Open? Closed? Does open cause any issues with rusting? Color? I'll spend at most $150-200 but would rather keep it under $100 if possible.
Here are the wheels I'm getting!
Old 03-03-2012 | 10:27 AM
I'm not a fan of open lugs, I don't like the way they allow/facilitate rust of your wheel studs. I also don't like the "unfinished" look, just a personal preference. Some of the expensive ones look cool but I can't bring myself to pay $300 for lug nuts, call me cheap.
I think just plain old black ones would look fine. Find some Muteki or something similar for $50-60 and call it a day.
Old 03-03-2012 | 10:36 AM
SwissCheeseHead
Thanks BB! I wasn't sure if the open ended lugs were actually functional in any way. I'm not a fan of rust. I had black Muteki lug nuts on my last car but with all the ballers out here I thought I'd not cheap out
Old 03-03-2012 | 10:55 AM
The open ended ones weigh a few grams less than a similar closed ended lug. A weight savings if about a half ounce each. Total weight savings on a full set is less than 10 oz. Whoopty do. It truly isn't enough weight difference to make any difference at all. Just a baller status thing.
That being said, NeoChrome or burnt Titanium ones look great with the right setup but they will set you back a few bills more than a normal set.
Old 03-03-2012 | 11:40 AM
Kuro's Avatar
Kuro
Don't get the open ended, I've been thinking to switch them to close ended one
Old 03-03-2012 | 12:53 PM
SwissCheeseHead
Thanks for the advice! It's such a small detail but like with anything else, it the details that count. Aluminum? Steel like Mutekis? Red, black, blue gunmetal?
Old 03-03-2012 | 01:06 PM
fairladyz34's Avatar
fairladyz34
I will probably never use open ended lug nuts again. My car was outside in a few days of heavy rain and since my wheels are cambered in when it's parked the water went right to the wheel stud and got a bunch of nice dirty rust water on the polished wheel lips! I will def never buy cheap open ended lugs again for my 3pc wheels
Old 03-03-2012 | 01:49 PM
SwissCheeseHead
What kind of lugs are you using now? Locking?
Old 03-03-2012 | 05:15 PM
fairladyz34
Ive used the closed end Muteki's which where really nice looking and held up well, and for my new wheels coming in I'm using a set of chrome McGard spline drive with locks. Simple, classy, and work really well. They even have a washer on the bottom of the lugs so when you are tightening them they don't scrape up the lug holes on the wheel.
OneSickBlackG
01-06-2016 08:49 AM
djdiskino
10-07-2015 08:31 PM
*ICE*
10-05-2015 03:05 PM
Falker11
09-09-2015 08:53 PM
xpcgamer
09-07-2015 07:10 PM
Quick Reply: Lug nut options/opinions
