KONI Sport Yellow Shocks and Struts now available for G37
Old 03-01-2012, 10:22 PM
  #46
TVPostSound
TVPostSound's Avatar
Mine just arrived.
Will install this weekend.
I think Im the second G37 to get Konis.
Our test fitter, never wrote a review.
Old 03-01-2012, 10:36 PM
  #47
dtran2714
dtran2714's Avatar
Originally Posted by SwissCheeseHead
Going for $840 now on tirerack. So tempting....
Koni Sport
Yes, very temping...
Old 03-06-2012, 06:04 PM
  #48
SwissCheeseHead
SwissCheeseHead's Avatar
Updates on this TV?? I know it's only been a couple days.
Old 03-06-2012, 06:09 PM
  #49
TVPostSound
Seeing if Lou at Amplified can install them tomorrow.
My weekend projects was installing the IPL front bumper.
Im not feeling too energetic now.
Old 03-06-2012, 06:20 PM
  #50
SwissCheeseHead
I know how you feel man....but they're goodies for the car! How can you not feel energized!?
Old 03-06-2012, 07:20 PM
  #51
mishmosh
mishmosh's Avatar
If I knew for sure that these did not alter the height of the fronts on the sedan, I would get a set right now!!!
Old 03-20-2012, 05:43 PM
  #52
FYI, they are on special at Tirerack.com currently. $840+ shipping for the set
Old 03-20-2012, 06:16 PM
  #53
jsp872
jsp872's Avatar
I'll try to find out if these will fit the awd coupe, i will call koni myself
Black Betty, can you give me a part number for this particular shock so i can call koni and talk to them about this
Old 03-20-2012, 07:51 PM
  #54
I don't know the part number. I just happened to see the price on tirerack by clicking the link in post #5 of this thread and posted it for the benefit of anyone looking to purchase them. I'm sure a vendor who carries them like Lou@ Amplified or Neal@tirerack can tell you.
Old 03-21-2012, 01:27 AM
  #55
TVPostSound
Look at Konis website, its updated for the G37
http://www.koni-na.com/cat_search.cf...&submit=Search
I can tell you first hand, they will not confirm it, as they have NOT tested a sedan, nor an X coupe, only a 2WD coupe.
The part number is a crossover from the 370Z that I talked them into testing.
If you can find out a 370Z strut fits a sedan, then it will work.
Old 03-21-2012, 07:55 AM
  #56
Do these have both compression and rebound adjustments on both the front and rear units?
Also, can someone who has the Koni/Swift combo installed on a coupe measure exact ride height from the ground to the center of the fender opening please? Preferably someone that has had them installed at least a couple of weeks and has had alignment. Thanks.
Old 03-21-2012, 10:47 AM
  #57
TVPostSound
Rebound only. Compression just happens to be just right for aggressive street.
Koni wont change the ride height as I measured the mounting bolt to spring seat when the OEM was off the car, and they match perfectly.
Ride height with the Eibachs did not change.
So it's basically the spring commanding ride height.
Old 03-21-2012, 10:54 AM
  #58
Thanks Pat. How many rebound settings front and rear? Can it be adjusted while the units are mounted without removing the wheels?
I know the struts won't change the ride height themselves, but I wanted to know the ride height (not the drop measurement) from someone who has the Swifts.
Old 03-21-2012, 05:52 PM
  #59
TVPostSound
2 turns on the fronts, 1/2 turn is a firm stock. I have it at 1 full turn rally nice positive rebound.
Strut shaft is hollow with a center adjuster.
Rears can be accessed with the car jacked up, an allen wrench into =======
10 clicks equals 2 turns. I have it at 5 clicks.
Old 03-21-2012, 06:49 PM
  #60
dtran2714
dtran2714's Avatar
When I get my Swifts and Konis installed I'll post it.
Quick Reply: KONI Sport Yellow Shocks and Struts now available for G37
