KW Variant 3 Coil Overs - Settings Advice
Fellow KW owners:
Looking for specific advice on settings...just bought the system and will install soon. I have done the search thing and could not find much on what people are using for settings.
I only want to drop the front about an inch or so and probably won't drop the rear at all.
Let me know what you have experimented with, with settings and what you like/run.
Thanks,
Sco1oter
Thanks,
Sco1oter
Fellow KW owners:
Thanks,
Sco1oter
Thanks,
Sco1oter
No takers..?
Thanks in advance for any advice you might want to share.
Regards,
Sco1oter
Just a preference thing; I am not partial to how the wheels look sitting in the wells when the fender gap is different at the top and sides.
My focus is getting the goofy looking front fender gap fixed and playing with the suspension settings. I also have a nice (expensive) exhaust system out back and the Stillen splitter up front and I am not interested in babying the car any more than I have to over hill and dale here in East Tennessee.
Do you have any experience with the KW's or preferences you would care to share?
Regards,
Scott
Regards,
Scott
I set mine as the instructions said, 9 clicks on top 1 full turn on bottom and seems to ride nice. I didn't slam mine either more the equal space around the 20's ended up 26" all around. I also installed front and rear SPC kits and rear toe bolts. Some have said they didn't need them but my toe was way off with the stock cam bolts ajusted all the way.
How would you describe the ride at those settings as compared to the OEM set up?
Sco1oter
Very close to OEM ride at higher speed at very low speed like a few mph hitting a bump or entering/exiting a driveway at an angle you can feel everything is stiffer. In the canyons hard cornering 40 - 50mph the car seems to handle better. There were corners with the stock setup that I'd get a little roll and some tire squeal that seems to be gone now running the same speed range.
I've also hit some hard bumps at different speeds to see if I was going to have the A arm hitting problem but so far it hasn't happened.
When I get a little free time I plan to go a click softer top and bottom to see If I can feel any difference. I was running 18's for a short time before the 20's and wish I could get back to the ride I had with them but I doubt that will happen by adjusting the KW's. Even that though is just a small thing on roads that aren't smooth.
Fellow KW owners:
Thanks,
Sco1oter
Thanks,
Sco1oter
The German's invade on President's day. Me and the coil overs have an 8:00 AM appointment at the shop.
Any tips, pointers, warnings, words of wisdom out there..?
Anyone...anyone...Bueller?
Regards,
Sco1oter
This is pretty much where I am on my KW's. BB also gave some good advice too. I've had mine for about 7 months. Ride is great. You will be very happy! Enjoy!!! Make sure u have some friends helping with install. Lol. My team and I put mine on starting around 7 and ended around 2am. Haha
