Cutting stock springs
Old 02-02-2012 | 11:50 AM
myk1013's Avatar
myk1013
Originally Posted by advan37
Get swift or tanabe , by cutting the springs you will make them shorter which means more pressure on coils , soon later they will damage.
Ok... isn't that the same when you get drop springs? (shorter springs)
Everyone's saying don't cut stock springs but nobody's saying why. (will cutting it change the spring rate?) will it make the ride bouncy? stiff? etc??
This is just a curious question.... Not planning on cutting mine, I'm on Eibach's and perfectly happy with them.
Old 02-02-2012 | 12:31 PM
hinomura's Avatar
hinomura
As an engineer I would say that things are designed the way they are for a reason. They are designed to withstand a myriad of situations/conditions/environmental hazards after lots of math, physics, and simulation work. When you modify a part you change the design parameter of the part and so all that math, physics, and simulation that went into the part design is pretty much out the window. What's left is variability and unpredictability. So if you want to cut a spring, by all means do so, but know that you are introducing a huge uncertainty risk into the safety and handling of your car.
Old 02-02-2012 | 12:48 PM
TVPostSound's Avatar
TVPostSound
Originally Posted by Highroller
Here's my dilemma,
I installed the Eibach lowering springs this weekend and although the new stance looks awesome the ride quality is not good. It's very stiff now... and when passengers are in the car they actually comment how rough the ride is and when I now go some speed bumps my exhaust scrapes. It's a trade off I cannot accept so I am thinking my only option is to go back to my original springs?
Here's the question, would it be "ghetto" to cut off say 1/2- 3/4's of an inch from the stock springs? If so, can anyone recommend a different spring that lowers the car about an inch but is not so harsh and will let me have passengers in the car?
FYI- the lowering springs are the only thing done to the car, I'm on stock rims
and tires.
Thanks
It's really not the springs, it's the dampers (shocks/struts)
They werent made for that short of a stroke.
Either wait a week or two to see Konis results on 370Z springs working on the G37.
Alternatively, try the Swift springs, I hear they are a little more gentle, they have a high rate, which would lead me to think you still wont be happy.
Old 02-03-2012 | 04:32 AM
TheLocNar's Avatar
TheLocNar
cutting the front springs Infiniti G37s coupe - YouTube
Old 02-03-2012 | 10:12 AM
Highroller's Avatar
Highroller
I ended up just going back to the stock springs for now.. but I did notice that the Eibach springs that were sent to me were for a coupe and not a sedan? I'm thinking that is why my ride was so rough...
Old 02-03-2012 | 10:48 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I don't know what the numbers are for cars, but for bikes, there is a recommended difference in height between unloaded suspension, bike with no rider, and bike with rider in full gear/accessories. The latter is called total sag. The idea is to position the suspension such that it doesn't bottom out, nor does it fully extend when in use. Preload on the springs (front and back) is used to make this adjustment. If you're using mismatched springs for your vehicle, you'll either get too much suspension movement that the shocks can't dampen (BB, proper use of the word in this context I think), or the springs will be so stiff that deflection will be minimum and ride exceptionally harsh.
Before blindly installing any suspension upgrade, do some research and find out what the various spring rates are, and how they relate to your particular application.
Old 02-03-2012 | 11:26 AM
Fentress24's Avatar
Fentress24
why not get adjustable coils? A more expensive route but if you want to drop and not have the discomfort of springs, spend a little more money and get height adjustablilty and a smoother ride overall.
Bad ride was my one fear so I went coils over springs this time around. Always had springs on my other cars. Will never buy springs again. Coils and night and day better than springs.
Old 02-03-2012 | 11:43 AM
JSolo's Avatar
JSolo
Just say no!!!!!
This link contains more technical data on the eiback p/n 6399.140
Eibach Springs : NEWS : INFINITI G35X SEDAN 2007-08
PK=Prokit, OE=what came on the car.
TECHNICAL INFORMATION
FRONT:
OE rate: Linear 61 N/mm (348 lbs/in)
PK rate: Progressive 40-96 N/mm (228-547 lbs/in)
Tubing: Yes
Bump-stop: OE
Dust boot: New Eibach Springs dust boot
Damper: OE
OE wheel center to fender: 402 mm (15.8 in)
PK wheel center to fender: 367 mm (14.4 in)
Front Alignment:
OE Camber = -0.35 (+/-0.75 deg)
OE Caster = 4.0 (+/-0.75 deg)
OE Toe = 0.04 (+/-0.04 deg)
PK Camber = -1.7 deg
PK Caster = 4.7 deg
PK Toe = 0.04
PRO-KIT will require PRO-ALIGNMENT kit 5.72130K installed to adjust alignment to OE specification.
Approximate installation time: 1.0 hr
REAR:
OE rate: Linear 67 N/mm (382 lbs/in)
PK rate: Progressive 65-93 N/mm (371-530 lbs/in)
Tubing: None
Bump-stop: OE
Damper: OE
OE wheel center to fender: 388mm (15.3in)
PK wheel center to fender: 360mm (14.2in)
Rear Alignment:
OE Camber = -0.25 (+/-0.55 deg)
OE Toe = 0.11 (+/-0.11 deg)
PK Toe = 0.11 deg
PRO-KIT will require PRO-ALIGNMENT kit 5.72265K or 5.72260K installed to adjust alignment to OE specification.
Old 02-04-2012 | 01:23 PM
minorthreat's Avatar
minorthreat
Originally Posted by sharkey
Yes, if your going to cut springs, get a Honda...
I had tanabes nf210, they drop the car about a inch and the spring is about 5% stiffer then stock.
Even Honda guys don't do this anymore... lol, I don't understand the logic in spending X-amount of dollars for a g37 and then cheaping out on suspension.
Old 02-04-2012 | 05:08 PM
DPE G's Avatar
DPE G
The springs are progressive....you can't just shorten them and expect good results. You are changing the spring geometry in doing so. They also seat in the struts a certain way and will no longer fit correctly. My h&r springs were low and not too harsh. But to do it right you should do coils or a spring and strut combo
Old 02-04-2012 | 05:38 PM
D_Rek's Avatar
D_Rek
Dont cut the springs....
si_driver
08-23-2017 01:35 PM
lobuzz311
16
10-17-2016 08:59 PM
james6980
10-09-2015 01:28 PM
Morgan Thompson
08-19-2015 04:44 PM
james6980
08-14-2015 04:32 AM
Quick Reply: Cutting stock springs
