Tire Rotation
Tire Rotation
Asked this question before but didn't get an answer. Do any of you guys or gals that have the sport pkg with the staggered setup rotate your tires regularly if so how from side to side and how often 5k?
Senior Citizen
My sense is that you did not get an answer because no active members with a staggered setup rotate their tires. In a way then, your question has been answered.
Interesting timing with your question...
I have the staggered set up and plan to swap the wheels (Nitto Invo's) side to side for the first time this weekend. My intention is to swap them and check the alignment every 7,000 miles or so (or every second oil change).
Sco1oter
Sco1oter
Sco1oter
Sco1oter
Directional tires can be flipped l-r by dismounting/remounting. This has the added benefit of neutralizing some camber wear.
Assymetric, non-directional usually has "outside" printed on them, which means although they can be flipped without dismounting from the wheel, camber wear will still be on the inside.
I no longer run staggered, but i do have directional tires which i rotate F-R every 5k, and L-R at the 15k mark.
MYG37.COM Platinum Sponsor
If staggered and asymmetrical, best you can do is left to right while keeping them on the wheels. If staggered and directional, best you can do is left to right but you'll need to dismount the wheels/tires and have them remounted for the opposite side of the car.
mmnjtwa
09-07-2015 02:27 PM
footballmania32
09-04-2015 03:06 PM
