Review Eibachs, 25mm Spacers & Front Camber kit... The final verdict
Old 03-28-2011, 10:46 AM
G37Sam
G37Sam's Avatar
Threads asking if a front camber kit is required with an Eibach drop come on a daily, so I thought I'd share my two cents since I've been rocking the Eibach ProKit (springs) for more than 2 years now.
My front setup: Eibach Lowering Springs, 25mm H&R spacers (causes more even more drop and camber).
I'm running 245/40R19 Dunlop Sportmaxx tires, been on them for 30,000 track-free kms (18.7k miles) now and here's what they looked like a few days back:
My alignment shop couldn't go below -2.2 degrees of camber so I let it be. I went to a tire shop today and had him swap the tires inside/out to see how many more km's I can squeeze out of them.
Assume I managed to squeeze another 10k out of them, that's a total of 40k kms. I probably wouldve squeezed 50k kms out of my tires had my camber been closer to OEM, but to me, a front camber kit shipped to the UAE would get me two brand new front set of Dunlops balanced and mounted, so is the extra 10k kms worth it? Do the math depending on how many kms you plan on keeping the car.
Old 03-28-2011, 12:09 PM
Loi
Loi's Avatar
maybe you can answer another question a lot of people been agruing about.
do camber wear tires out faster?
Old 03-28-2011, 12:48 PM
Steveo47
Steveo47's Avatar
Well how long do you plan on keeping the g. I know you already have 100k km on it.
If your going to keep it for 250k more, than you would get the moneys worth in the camber kit
Old 03-28-2011, 12:51 PM
Loi
Loi's Avatar
Maybe you should put this into consideration on whether or not to get a front camber kit; at the end of the day, you can sell the camber kit and get a good amount of money back, vs. wore out tires that are not resellable.
Old 03-28-2011, 03:13 PM
G37Sam
G37Sam's Avatar
See based on my math I'd have to go through 8 sets of tires before breaking the cost of a camber kit even, and since I sort of like the look of slightly cambered fronts, I'll probably pass.
By the time my car hits 300k kms it'll be fully stripped and track prepped I'm hoping
Old 03-28-2011, 03:34 PM
datacenter
datacenter's Avatar
G37SAM:
What is your off-set on your rims?
I'm getting the Eibach spring kit installed on Wednesday and I ordered 19x8.5 rims with a 35mm offset. I'm thinking now I should of order an offset of 20mm..
thoughts?
Old 03-28-2011, 03:56 PM
G37Sam
G37Sam's Avatar
I'm on the OEM 19's, 19x8.5 + 43mm front, 19x9 +45 rear
Old 03-28-2011, 04:14 PM
eksigned
eksigned's Avatar
i was just debating on a drop. i've always been under the impression that oe specs with minimal camber was fine. guess not.
then again, you said you had spacers? i wish i knew more on the topic, but i don't. WILL OE specs + eibach drops with no spacers yield better even wear? + correct alignment (toes especially).
Old 03-28-2011, 04:19 PM
Loi
Loi's Avatar
I believe this thread will help answer your question: https://www.myg37.com/forums/brakes-...g37-coupe.html
He was able to get a ~-1.6 degree camber in the front, vs Sam's -2.2
Old 03-28-2011, 04:55 PM
soundmike
soundmike's Avatar
Originally Posted by G37Sam
Threads asking if a front camber kit is required with an Eibach drop come on daily, so I thought I'd share my two cents since I've been rocking the Eibach ProKit (springs) for more than 2 years now.
Sam, not being able to judge the tread depth on the remainder of the tire, but just by looking at your wear that seems more like toe rather than camber wear.
Haven't you rotated the tires during it's life-to-date?
Old 03-28-2011, 05:06 PM
G37Sam
G37Sam's Avatar
No rotation was done prior to today, I had my alignment done a while back and they were brought close to spec can't remember the exact numbers
Old 03-28-2011, 06:04 PM
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
Pics of the rear wheels with the 25mm spacer and stock tires please
Old 03-28-2011, 11:25 PM
G37Sam
G37Sam's Avatar
My rears are sitting on 20mm's though
Old 03-28-2011, 11:29 PM
cereal2k
cereal2k's Avatar
OK. Are you planning on moving to 25s there also?
Old 03-28-2011, 11:41 PM
chuckie311
Drop A Gear and Disappear
chuckie311's Avatar
yeah ill pass on the camber kit as well
Quick Reply: Review Eibachs, 25mm Spacers & Front Camber kit... The final verdict
