Help Camber feels weird when driving..
Old 03-22-2011, 11:22 PM
ShyAznB8oi
ShyAznB8oi's Avatar
Hey guys I got my SPC camber kit installed by Amplified Motorsports today and they did a great job.. As soon as they were done, I took my car to the shop near AM and got it cambered -4.0..
When I was driving on the freeway, I felt like I was just barely making any contact on the pavement? And my steering wheel got pretty sensitive.. I was not going more than 70 mph from LA to SD.. It had that fish-tail scenery feeling..
IT FEELS REALLY UNSAFE DRIVING. ESPECIALLY TOMORROW RAINING .
If you guys can help me out, that would be cool.
Do you think I should get my local Firestone shop to check whats up if the guy did my alignment correctly?
Old 03-22-2011, 11:45 PM
P Casey
P Casey's Avatar
did they do a full alignment with toe and caster
Old 03-22-2011, 11:57 PM
MOB
MOB's Avatar
Did it feel like a slight twitch of the steering wheel made the rear follow with a snappy/fishy sensation? Like the rear was loose?
Old 03-23-2011, 12:06 AM
Weiboy718
Weiboy718's Avatar
why is it at -4 camber???????? definately need to know why.
Old 03-23-2011, 12:47 AM
wlmngtn
wlmngtn's Avatar
show some pics, for fun of your set-up, of course.
Old 03-23-2011, 01:05 AM
ShyAznB8oi
ShyAznB8oi's Avatar
Yes that is correct. What you described is what I am having
Old 03-23-2011, 01:08 AM
ShyAznB8oi
ShyAznB8oi's Avatar
"description of labor";
2 rear wheel alignment
Only camber rear -4.0
Costomer request
Does that mean.. He ony set my camber at -4.0 and did not align the toe and caster?
Old 03-23-2011, 01:11 AM
MOB
MOB's Avatar
I dropped my sedan on Eibachs and pre-alignment the car felt so good. Post alignment I've got those same symptoms.
Old 03-23-2011, 01:12 AM
Loi
Loi's Avatar
Do you realize that -4.0 degree camber is not normal? Which could cause your tires to "barely make any contact on the pavement".
Old 03-23-2011, 01:39 AM
ShyAznB8oi
ShyAznB8oi's Avatar
i wanted -4 because i wanted the look. i am probably going firestone tomorrow and get -2.5 camber instead of 4.. hopefully it will fix my problem?
Old 03-23-2011, 01:54 AM
ipitythefoo
ipitythefoo's Avatar
^LOL there is your problem
Old 03-23-2011, 01:58 AM
ShyAznB8oi
ShyAznB8oi's Avatar
which would be?...
it also looks like the tire has full contact on the pavement?
Old 03-23-2011, 02:54 AM
bingpwr
bingpwr's Avatar
Looks like it, but it probably isn't. Your load is going to be mainly in the inside portion of your tires, causing that weird driving symptoms.
Old 03-23-2011, 02:59 AM
P Casey
P Casey's Avatar
um still dont understand if they adjusted the caster and toe like a normal alignment, i understand they did camber but he prolly was at almost 2.5 or more with the drop....maybe im way off but in the job desc. it just say adjust camber -4
Old 03-23-2011, 03:47 PM
ShyAznB8oi
ShyAznB8oi's Avatar
well i took it to firestone, they did not want to work on it because i cannot get up on their alignment rack.. and said if i go -2.5, i may have rubbing issue.
then took it to evans tire, told me the same thing also..
now im stuck with -4, until i find a shop that will do my car -2.5..
Quick Reply: Help Camber feels weird when driving..
