Help Camber feels weird when driving..
#37
more negative camber will not give you more flush look when your wheels are already within the fender line.
you do not want to run any more negative camber then necessary.
and -6 camber is not a pretty sight
#39
I drive a cambered car and have first hand experience in telling you that camber doesn't eat tires.
You should know that camber causes uneven load, and thus, uneven wear, while toe causes scrub, causing the tire to wear really quickly.
Remind me (and everyone else on this board) not to go to you for an alignment. You probably just look at a screen and call it a day when its 'in spec'. I get my alignments done with yardsticks, tape measures, and levels.
Here's a question for you.
G37 pulls left under load, goes straight off-load and under braking. Alignment checks out fine on the rack. There is no suspension damage. What's causing the pull?
#41
Good for you.
You cant come to me for an alignment, I stopped being a tech 22 years ago.
Lastly who are you to judge my past work?
I was the best at what I did then as what I do now!!!
#43
Ahh this is why I cambered.. Went Costco and bought 3 packs of water and a pack of gatorade.. And some other stuff also.. With 2 people. If I was not cambered, I would be rubbing on my lip or tire badly.
![](https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/189978_1648928578518_1096058191_31428128_1232796_n.jpg)
![](https://mail.google.com/mail/?ui=2&ik=85a3000a6d&view=att&th=12ef4e467924da2d&attid=0.1&disp=inline&zw)
the faces of people I drive by are just.. "WTF"
4DRZ
03-28-2017 01:54 PM
cyberone28
09-23-2015 01:56 PM
