Eibach with 19" or 20" rims..
I have a 2009 G37x and I'm going to lower it with a Eibach spring kit part #6394.140. Its looks like this will lower the front 1.9" and the 1.6" in the rear.
After this is complete, I'm headed to get some new rims/tires and I need some advice to the experts on here.
My questions are.....
1) Are the 19's are going to be a better ride than 20's? I still want a good comfort level.
2) I wanted a slightly wider tire/wheel in the rear, any drawbacks with this setup?
3) I realize I'm going to need an alignment after the springs are installed, correct?
1. yes, your ride will be a little bit less in comfort...the percentage is less then 15%.
2. definitely get a slightly wider tire in the rear...no drawbacks.
3. yes, definitely get an alignment after the springs are installed...some people say get it about a week after the spring installation for the springs to settle...so either right after, or about a week after.
i just ordered my eibachs for the AWD aswell. im interested in this topic in the near future
yes you will need an alignment. you wont be able to get into factory specs without a camber kit, but most of the AWD guys i asked about the eibach didnt bother with a camber kit. i dont know wether just maxing out the factory camber kit would line everything up?
Just to clarify one thing.... Since you have an AWD X, you need to keep the overall F/R tire diameter as close to the same as possible. This will cause the least amount of potential issues with the AWD system. The actual tire size will depend on if you choose 19's or 20's. For 20's, I think the closest sizes you can find are 245/35 (F) and 285/30 (R).
1) 19's will be a better ride than 20's in the comfort department.
2) I don't see any drawbacks fro running a staggered set up with the X. It will actually look 10X better IMO.
3) definitely get an alignment ...... after a couple of weeks. Let everything settle in first.
Thanks for the help guys.. Looks like i'm going to stick with the 19" rims..
Though there are a ton of places online to purchase new wheels, I would like to see them first..
Can anyone recommend a wheel shop in the Chicago area with a LARGE selection?
I have an AWD coupe and was looking into doing this as well. My only concern is I live in the Northeast and with all the potholes, I'm afraid the drop would damage my fender/bumper. Anyone have any experience with this?
Also, would there be any reason to do a drop and not get rims? The ones I want are out of my budget at the moment...
optikol
01-28-2016 07:31 PM
User 122320
10-05-2015 03:03 PM
