Help Help --> Rear Bumper bracket issue
Old 04-20-2011 | 01:52 PM
  #31
Weiboy718's Avatar
Weiboy718
Originally Posted by redrover23
I'm just going off the info in this thread but, aftermarket bumpers do not have the 6 snap joints on either side? And this is the reason for the bolt necessity?
In other words, if your aftermarket bumper has the snap joints->you could shave the bolt off?
TIA.
let's use the ait rear bumper for example.
THat bumper doesn't come pre drilled for the snap point but You can easily drill out the holes. The bumper is heavy and will sag so you will need to install that bolt for support
Old 04-20-2011 | 04:04 PM
  #32
redrover23's Avatar
redrover23
so if you use the snap points the bolt is not needed? or are both the snap point and bolt are needed for fiberglass (cause it is relatively heavy)?
THX!
Old 04-25-2011 | 11:36 AM
  #33
breftayka's Avatar
breftayka
Not that it's safe or the correct way to do it, but I just let my wheels rub so much it removed that bolt on its own lol.
Old 04-25-2011 | 01:34 PM
  #34
RaizinCayne's Avatar
RaizinCayne
Originally Posted by jmlenz
@raixincayne - Thanks for the pics by the way! I had a good feeling it was this bracket but pics always help. Correct me If Im wrong but your bracket is still factory you just trimmed the fender plastic?
Negative sir. Everything you see in my pics is completely stock. Havent touched the bracket or fender....yet. I will be shaving it down when i mount my tires/wheels.
Old 08-30-2012 | 04:10 AM
  #35
a205's Avatar
a205
is it recommended to paint after shaving the bracket to prevent rust or is it fine to just leave it?
Old 08-30-2012 | 12:24 PM
  #36
BooSa37's Avatar
BooSa37
No........
Old 09-04-2012 | 04:58 PM
  #37
a205's Avatar
a205
No what?
Old 09-04-2012 | 07:33 PM
  #38
BooSa37's Avatar
BooSa37
No what?
No need to paint or anything
Old 09-04-2012 | 08:12 PM
  #39
jujubii's Avatar
jujubii
get some touch-up paint or some touch-up clear to cover it. the bracket is steel (or whatever metal the fender is made out of). if it gets continually wet or exposed to the weather, it may rust.
Troop12
05-09-2018 03:40 PM
Topher9425
12-01-2015 04:00 PM
ryang37x
08-21-2015 04:27 PM
Amarsingh
08-08-2015 02:31 PM
dholmblad
08-04-2015 11:58 AM
