Review Killed my wheel gap: Springs, spacers, and sways review + Photoshoot
Introduction:
I recently installed Eibach springs, H&R 20 mm Spacers, and Eibach Sways on my 2010 G37 Coupe. The car is my DD and does not see the track, as such my goal was simply to get rid of wheel gap, add some stance, and slightly increase handling, all without compromising ride quality. I choose springs over coilovers primarily because of cost, when I added on the cost of parts and labor of front and rear camber arms it quickly became a downward spiral of additional cost that I did not want to get into.
Vendors:
Parts were purchased from Lou @ Amplified, he gave me a great forum deal and was able to help suggest the right swaybars for my application. The parts were promptly shipped to my door, and I was extremely satisfied with Amplified's service. Install and alignment was performed by Pro Tuning Performance of Fort Worth. I cannot recommend them highly enough, after meeting them I instantly trusted them to work on my car, and they certainly treated it as if it were their own.
Performance:
Since I installed springs and sways simultaneously, it's hard to attribute performance increases to one or the other. Pro Tuning also was able to get camber to -1.4 F, -1.8 R, toe neutral, so this also contributes to lateral grip. The car feels more predictable and handling neutral over stock. Body roll is greatly diminished, though not completely eliminated. The car is more controllable and predictable during slide or drift conditions, however I do not feel the sways excessively promote oversteer. Overall, I feel this is a great combo for some increased performance that certainly does not break the bank.
Ride Quality:
Obviously, Eibach springs are stiffer than stock. Subjectively, it feels about 5-10 percent stiffer, I can definitely live with it. There is no excessive bounce with the springs. The car feels slightly less composed over uneven pavement, sometimes going into a slight "side-to-side" motion. I attribute this to the stiffer swaybars, and is pretty much par for the course. The Eibach sways are set at their most conservative setting front and rear. I imagine it would be easy to induce oversteer by going soft in the front, and stiff in the rear. I have had the spacers on for 200 miles so far, and have not had a chance to re-torque them. They have zero issues, no vibration whatsoever.
Compatibility:
We ran into an issue with my FI Catback not clearing the thicker rear swaybar. It was resolved by grinding off an exhaust clamp, and rotating it out of the way.
Aesthetics:
I'll let the pictures speak for themselves. I am very happy with how everything turned out.
Vendors:
Performance:
Ride Quality:
Compatibility:
Aesthetics:
Which H&R? DRS or DRM?
Ive been debating getting the 15 mm H&R, but Im going to wait until I get new tires because Im going wider to determine which spacers to get.
Any up close side shots of the wheels? The pictures look nice, but its hard to see the actual wheels from such a far distance.
Thanks for the replies. They are the spacers that bolt over your existing lugs, I forget which kind that is. I will be doing a more extensive shoot next week when the weather warms up, I'll take note of pic requests until then
Other than that, looks pretty sweet and give the eibachs some time to settle and you'll fall in love with them, especially on smooth roads.
