Are wheel spacers safe?
Hubcentric refers to helping center the wheel on the hub, which will reduce vibration that can occur with just regular bolt-ons.
Like any modification, are perfectly safe if installed and maintained properly. They are easy to install, you just need to ensure proper torque on spacers and wheels. Then you should check them every once in a while to make sure that they are maintaining proper torque.
+1 for H&R.
+1 for H&R.
Did some more research and found that hubcentric are perfectly safe if installed and torqued correctly. The hub flange accepts the center hole in the wheel, acting like an extension of the axle. Stillen's website was selling H&Rs for like 140, although I couldnt tell if that was for a set of 4 or individual because if not...yikes.
i been running mines for a long time now. They are hubcentric FiC ones like these:
FIC Wheel Spacers - More Japan
Since 2003
![BRB](https://www.myg37.com/forums/images/smilies/brb.gif)
ive always wondered which 20mm H&R ones would be more safe. the DRM or the DRS?
Not to jack your thread. Just FYI.
Have H&Rs 15mm front and 20mm rear on my IS250 for 4 yrs (40K + miles) without any problems. No vibration or noise. Still have them on.
Not running spacers on on MY G coz I'm flushed with my current setup.
04G35NYC
12-24-2015 01:00 AM
KZK
Canada
09-02-2015 05:30 AM
