Does neg camber make your steering wheel shake
hey guys im just wondering if anyone who is lowered with 20's experiencing steering wheel shake at 60-80mph my tire guy balanced the wheels liek 6 times (road force)
i had the hub rings swapped out 4 times and the wheel runout test shows no abnormalities. just wondering if neg camber up front or rear would do this? any help would be appreciated thank you
ps: here is a pic of my alignment stats
The vehicle runs negative camber straight from the factory. Its part of a sport tuned suspension. Camber will not cause your steering wheel to shake. Vibrations from certain speeds is usually a direct result of unbalaced wheels and tires or improper torqueing of lug nuts. Are you using plastic or metal rings?? Ive never had luck with those plastic type hub rings. If i run my wheels up front without metal hub rings or with the plastic rings, i get vibrations. If i put the metal rings in, i get nice and smooth driving.
ya we road force balance the wheels and did a wheel run out test both perfect 0 so idk why it would be doing that, what is the proper torque spec? and where can i get metal hub rings?
NextLevel Performance
hmm...I never thought of this....but I always have set the car partially on the ground to keep the wheels from spinning. Never thought about having someone press the brakes to keep the wheel perfectly centered, but at the same time, you're not really "holding the wheel up" when you're torquing them on either to keep them centered. The wheel is hanging.
Hey You know what you gotta do with your wheels?
you gotta do these three things, and I gurantee its gonna get fixed.
Index Tires
Road Force Balance
High speed on car balance.
Total cost about 250 dollar from very reputable shop, but it is worth it.
No matter how many times you do road force, it does not solve the problem.
And from the your older posts, I could see that you are a very negative person. I am not trying to start arguement with you but you should calm down little bit.
I can't tell you how to live, but I can tell you that it doesn't look good.
Index Tires
Road Force Balance
jarena2104
I know youre banned, but can still read these posts.
I had some time to kill while waiting for a producer, and wasted 30 minutes of my life reading your previous posts spread across this forum.
Bottom line:
You NEVER complained about vibration with Vossen wheels, until you installed spacers.
12 pages of drama during your offset freakout, never do you complain about vibration.
Driving 250 miles to settle your coilovers, never do you complain about a vibration.
A lot of whining with noise, but no vibration.
I think you issue has been resolved.
Now Sam can lock THIS thread!!!
Bottom line:
mauiwowie
08-16-2015 06:01 PM
350zrunnin12s
08-09-2015 09:55 PM
