how to turn off tpms warning light?
#31
Also, don't they have to be in position in the wheel areas to send the signal to the car? How would the car recognize them if they are in the trunk? Whoever said this, did they confirm that this actually works or is it just speculation? Because if that's true, you could just put them inside anything that's got 35 psi of pressure in it and keep them anywhere inside the car to make the light go off.
#32
I’ll never understand why some owners would go to all that trouble of making pipe bombs, wheel barrow tires in their trunk, or even black tape to cover up the light, when all they have to do is install the sensors on their wheels. (duh) I’m sure there’s a wide selection of aftermarket rims that are compatible with their car’s TPMS.
And, as unimportant as it seems, they get the advantage of being alerted if a tire actually does loose pressure.
#33
#34
#35
Coming from an aviation background, we learned never to ignore a warning light, as may mean anything from a minor inconvenience to the airplane going down in flames in the next two minutes.
As for the TPMS light being on all the time, it may mean nothing if TPMS is disabled, or a impending flat tire leading to a sudden blowout and a potential serious accident.
#36
#37
Old thread and don't know why it was bumped but the obvious answer is to make sure all your tires have TPMS installed and working correctly. It can be the difference between a good day and a really bad day so the extra money it cost to have them really shouldn't be a part of the equation.
#38
I’m afraid I don’t understand what you’re saying. Are you saying it’s OK to ignore the light if you know the system is inactive? That doesn’t seem to be in the realm of common sense to me.
#39
Just say no!!!!!
^^I ignore my tpms from the months of late november to late march each year. The winter wheels have no tpms installed and the light turns on after driving a certain distance with the winter wheels installed. Tire pressures do get checked periodically during the winter.
#40
My TPMS saved my butt from an unpleasant day by alerting me of this
Put 50lbs of air in the tire with a slow leak to get me home and a repair
Telcoman
#41
But it’s an old topic that certainly many of us are tired of hearing. There’s basically three schools of thought among the anti-TPMS group:
• I check my tires regularly so I don’t need it.
• It’s too expensive when I change to winter tires.
• We’ve driven cars for over a hundred years without it and got along just fine.
Swaying anyone away from such positions can only be changed by having a near bad experience with TPMS saving the day, or worse, having an actual bad incident with the system bypassed.
telcoman (07-26-2015)
04G35NYC
12-24-2015 01:00 AM
KZK
Canada
09-02-2015 05:30 AM
