Help Eibach Wheel Spacers vs H&R Track +
I am debating between Eibach Pro Spacer
30mm Spacer / Bolt Pattern 5x114.3 / Hub Center 66.1. $101.75 Pair.
Counter Part H&R Track+ Wheel Spacers.
5/114.3 66.2 Stud 12x1.25 DRM 25mm 5065662 $ 149.95 Pair
I really want to go aggressive and put 30mm spacers, which also fit 370z according to Eibach. They are both aluminum so I am not too worried about and Eibach offers million mile warranty.
All specs match except for centric ring size. H&R is 66.2mm and Eibach is 66.1mm.
Will 1mm make big difference? Thank you for your thoughts.
30mm?? Now that's some cojones
I recommend going with H&R's, every race-prepped car I've seen on the track here is using them (not much of a valid reason but thought I'd throw it in)
The larger hub ring also translates to less vibration chances
Majeed Bader
10-08-2015 10:52 AM
