Help Is Dropping your Vehicle Really Worth it?
Hey people I need your to hear your opinion on this. I about to install 20's on my car and looking to lower it also. I will be going with Eibach Pro-Kit Lowering Kit if and when I do because I've read that it's good and also good for daily driver.
My question though is whether this is worth the money. I mean I don't race my car, don't really drive aggressively but I do want a very good look. So is lowering make your car look that much different and is performance and ride improvement that much noticeable?
I just want to hear your thoughts/recommendation on this subject. Right now I will most likely do it after I shop around a bit. Also let me know where I can find a good deal on the springs online.
I should mention that my tire specs are 245/35/20 Front and 285/30/20 Rear if that makes any difference.
Thanks in advance.
Thanks in advance.
Yes, IMO dropping it will make it look much better and also handle better. You will lose a little bit of ride quality from the stiffer springs and shorter tire sidewalls as a compromise, but how much is subjective. Most will agree not very much at all. Do it and don't look back.
PM several of our forum vendors to see who'll give you a great deal on the springs. A number of them carry them in stock.
tire sizes you provided is important, but the offset of the rims is important as well in knowing about rubbing issue. But most likely, since you are gonna run eibach spring, you wont have to worry about rubbing.
And yes. dropping is must. I think it worth more.
I rather drop my car and keep the stock wheels, than get 20's without a drop
Dropping on Eibachs I think is perfect for those that aren't tuners, aren't going to go all out on there car, but want some increased looks and performance. Gets rid of the gap, so the looks are immediately better. But like BlackBetty said, you will also get some increased performance. Your car will handle noticeably better. And on Eibachs, you can still go over speed bumps without worry.
Front: 5x4.5 +30mm offset
Rear: 5x4.5 +38mm offset
Front is 20x8.5 and Rear is 20x10
