Review Temple City Auto Repair: Alignment
He puts the car on a lift and gets under the car while he's looking at his alignment screen to make sure the adjustments he's making are right on spec. I got about 4-5 alignments done from firestone tires and I never seen em do that.
Temple City Auto Repair 9237 Lower Azusa Road, Temple City CA. Ph#(626) 287-6417
Thats how an alignment is supposed to be done, what the f#@% do they do at Firestone??
Thanks for reminding me, I had to put my stock front arms back on, need Henry to reset my toe.
At one point I went into firestone to get an "alignment" cause I had just gotten my camber kit installed and my camber and toe were off so they tell me that they can fix the toe but they refused to even try to adjust my camber cause they supposeably didn't want to damage anything which is crap so I went home with -4 camber lol.
Bump up for Temple City alignment.
I had a hair up my *** this week, and cut the rear spring perch down 1/2",
and needed realignment. Called Henry, told him Saturday AM was the only time I could go down there, he happily booked me!!.
I drive over 30 miles to have him align it.
This is what a good alignment should read.
Eibach springs with front and rear SPC camber arms, and toe bolts.
I wanted just a little bit of neg camber on the front.
Bubble gauges do fall out of calibration, I learned alignments in the mid 70s with a bubble gauge and tram gauge. Many errors can occur. There is absolutely nothing wrong with a computer alignment machine, as long as you know theory.
With that being said, you should be using a typewriter with cups and strings!!
Driving a car with a carburetor, and distributor points.
FlyIce
09-29-2015 04:07 AM
