Stock tire measurements on G37S Coupe
Old 11-08-2010 | 10:33 PM
FukinG37S's Avatar
FukinG37S
What is the tire sizes I should be running for best performance and handling, and acceleration?
I want to keep the cars engineering close to stock as possible to drive the car the way it was suppose to be built, and allow the car to perform at its maximum potential?
Do i run a 245/35/19? or a 245/40/19? front?
What about rear?
Old 11-08-2010 | 10:54 PM
wakeboardr116's Avatar
wakeboardr116
The stock setup is 245/40/19 rear and 225/45/19 front. For the stock wheels the most popular setup seems to be 275/35/19 rear and 245/40/19 front. I believe this is also the closest to the original tires diameter.
Old 11-09-2010 | 01:05 PM
joo030879's Avatar
joo030879
I think 245/40/19 for the front for reasons below
225/45/19 front will wear off much faster than rear 245/40/19's. Our G37 if we don't replace alignment kit. The outer part of front tire will wear off much quicker than the inner side. Especially if you drive and corner at greater speed.
So when you have to change your front tires, instead of buying another set of 224/45/19 for your front. Place 245/40/19's from rear tire to the front. And purchase for few dollars more 275/35/19's, for the rear tire.
And 245's lasted little longer than 225's when placed on the front.
Other than economical reasons your G37S will look much better. Drive will not alter as long as you don't modify the car further.
james6980
10-09-2015 02:28 PM
drewfinity
08-20-2015 09:17 PM
Hiryuu
08-07-2015 08:08 PM
JakeG37
08-03-2015 10:28 PM
