Help Factory camber toe setting for g37 sport sedan
my alignment has been tempered and I would like to restore to a factory angle. Does anyone know the front and rear camber setting for g37 sport sedan ( maybe toe if any) ?? Thanks in advance.
okay this is the coupe, but I have found the service manual for sedan. Theres minumum, normal, and maximum. At what setting does the car come out (normal, minim or max)?
Thanks for clarifying... and this leads to one more question.. The rear camber spec arranges between -.42 deg to -1.42. That's a full degree difference and seems like a of difference... Let's say.. if my car's rear camber is at around -.5 and if I change the camber to -1.4, will there be a noticeable difference when driving?. (total around 1 deg).
Dialing some extra negative camber can help your car corner a little better but wears tires a little faster. But too much negative isn't good. I just had my car aligned and have the front camber set at -.5 and rear at -1.6. I'll have it set to -1.8 next time because my rear right tire rubs a tiny bit on big bumps.
Lowering your car's center of gravity (ride height), stiffening the suspension with bracing, and stiffer sway bars all decrease body roll. Not negative camber.
I see. I haven't lowered anything. I have replaced my tire with a bit lowerend (falken utqg around 300) but I also had my alignment done twice (first shop screwed up so second shop did everything just perfect but I don't know if the camber is less or more aggressive than my previous stock angle. He said it is a bit over the stock but I should go back and ask him for the number.
Whenever I make sudden jerk, I feel the body roll.. or it feels like the back of the car is responding slower. I don't know if this comes from soft sidewall or less aggressive camber angle... so I am dead frustrated atm..
Get stiffer sway bars to greatly reduce the body roll, the camber isn't the culprit. Also if your tires have soft sidewalls that would make it seem worse as well.
http://www.streetfire.net/video/infi...kis_204490.htm
