We are looking to pick up a '11 G37S sedan. I don't need a drastic drop, I just don't want it to look like a Subaru. I would also like to preserve the ride quality and handling. I could also do without monthly alignments and going through tires every few months.
So what is the simplest way to drop the car just a little (for aesthetics)?
yea there are many views but my car is within spec ..my tire wear is fine and has been for the past 8 months. what it comes down to is how good of an alignment shop you go to
I've read that the Nissan 370Z OEM springs will give you a subtle drop (3/4 inch) and keep the suspension within factory specs.
3/4 of an inch? LOL! Thats not worth it!
Eibach is your best bet:
a) Suspension will be a bit firmer
b) You will lose the ugly gap and the Gs look good on Eibach.
c) You wont need a camber kit if you go to a good alignment shop and you dont drive spirited. If anything the fronts are not 100% in spec but good enough to not give you tire wear issues. Go over an inch and you'll need camber kits.
If you want only 1/4 of an inch drop I suggest letting the air out of your tires
