Least intrusive way to lower the G37?
Old 10-06-2010, 12:15 PM
htran16
htran16's Avatar
will adding 15mm spacers all around with eibachs create more negative camber?
Old 10-06-2010, 02:05 PM
Naripsta
Naripsta's Avatar
Originally Posted by Presto
do it right, get the camber front and rear camber kit. im sure many will say you dont need it, IMO it is needed if you want to preserve your tire life
Camber's not the major role in killing your tires, it's the toe.
So no, you won't need it. Maybe if you had coilovers and went lower than the Eibach lowering spring kit, then yes.
Old 10-08-2010, 11:15 AM
TVPostSound
TVPostSound's Avatar
True, but the camber WIILL wear tires.
Old 10-08-2010, 11:47 AM
ScottyBeGood
ScottyBeGood's Avatar
Originally Posted by Xcalibur
3/4 of an inch? LOL! Thats not worth it!
Eibach is your best bet:
a) Suspension will be a bit firmer
b) You will lose the ugly gap and the Gs look good on Eibach.
c) You wont need a camber kit if you go to a good alignment shop and you dont drive spirited. If anything the fronts are not 100% in spec but good enough to not give you tire wear issues. Go over an inch and you'll need camber kits.
If you want only 1/4 of an inch drop I suggest letting the air out of your tires
+1 on Eibach... To be on the safe side regardless of how good the shop is or not, you may still want to pick up the rear camber kit. Last thing you want to have happen is to find out you are too negative and have to purchase the kit and redo alignment again...
Old 10-08-2010, 11:55 AM
TVPostSound
Technically, yes.
But the amount is next to nothing.
Before anyone flames this:
One word...Archimedes!!
Old 10-08-2010, 12:45 PM
TheIvoryG
TheIvoryG's Avatar
Lets not forget that some negative camber is actually a really good thing, because your car will handle like it is on rails. You will just also chew through tires a lot quicker. So...pick your poison...
Thedbarz
33
02-09-2016 12:05 AM
sLADe781
32
11-28-2015 03:23 AM
ladydriveng37
10-11-2015 05:23 AM
Ricio1991
08-27-2015 10:17 AM
Javilowks
08-07-2015 04:41 PM
Quick Reply: Least intrusive way to lower the G37?
