Does TPMS sensor give actual pressure
#33
i got a set of summer wheel and a set of winter wheel
My TPMS lights up after i put my summer set on, brought it to the dealer they said it needs to be reprogrammed.
they wanted $65 for it
They also said later in the winter when i put my winder set same thing will happen again.
Since i only average 4000miles a year, i guess i will be cheap and skip the $130/year.
#34
![](https://cimg7.ibsrv.net/gimg/www.myg37.com-vbulletin/500x421/80_s_l500_869d048b45c22475435cd4e434b10fed27a854c0_2cf3bf24950d42562aabfbbb0ce368831b4ee69e.jpg)
You can also manually reset it yourself with this hack thread
Read carefully.
#35
thanks!
indeed i read the hack thread before - way to advance for me.
and thanks for the info on the DIY gadget! i will think about it.
Given the TPMS on G only warn us when 1 of the 4 tires has low pressure (my old 350Z tells the individual tire pressure) i dont mind going to the gas station and top up the air once a week or so. however it does trigger my OCD with the orange ! TPMS light goes off constantly (starting to get used to it now)
an off topic question, i got one of the pen style tire pressure thingy, i notice when i plug it in fast, the tip will shoot out and overs >50psi, when if i plug it in slowly, it should show a different PSI, so pretty much i keep getting different PSIs with multiply tries each time.
what is the correct way to record the reading?
Should i invest one of the mobile air pump with pressure reading gauge?
04G35NYC
12-24-2015 01:00 AM
JG_G37
09-19-2015 09:07 PM
m3clubracer
09-16-2015 03:08 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
