OFFICIAL: Post your DROPPED Sedan side profile pics?
Is there no consolidated Sedan drop pics thread? Couldn't find one, surprisingly. If this is a FAIL, lock or delete this. If not, post em up. Let's see your Sedan drops from the side. Please post what setup you run, drop amount and alignment specs if applicable. Also, whether you rub or not!
*Tanabe NF210
*1.0 Front/1.3 Rear
*Alignment to factory specs. Rear camber slightly more negative than spec; about -1.8.
*No rub
*Tanabe NF210
*1.0 Front/1.3 Rear
*No rub
07-08 G35 Sedan Eibach Springs
Specs:
Front: 20x9 +25 w/ 245/35/20 Yokohama S-drives (-1.65 degrees of camber on the drivers side, and -1.9 on the passenger side). I rub slightly on my inner fender liners on the front.
Rear: 20x10 +35 w/ 275/30/20 Yokohama S-drives (-1.65 degrees of camber). No rubbing with this setup.
Specs:
Are those 19" wheels?
Ron
Ron
*Tanabe NF210
*1.0 Front/1.3 Rear
*No rub
*Tanabe NF210
*1.0 Front/1.3 Rear
*No rub
I forget which vendor it was. Maybe cs motorsports or something. He's in queens, ny. But I'm gonna making the eibach switch. Want to go a little lower. If your interested in buying my tanabes, pm me. I still have the original box and everything. Bout 20k miles on them.
DJ H,
Your set-up is the best I have ever seen on the G sedan! The 20mm spacers gives the car a classy but sporty look and that's what I'm after. I'm sure it doesn't matter which spacers brand since they all will accomplish the same principle. I'm on 18" Enkei's and my car will look like yours in the near future
Thanks again,
Ron
Thanks again,
Ron
